My tranny won't shift right
Ok...First gear shifts about where it should i would say around 4500-5000...it goes to second and then shifts at about 2500....then goes to third...It's a th-400 tranny, tach doesn't work, i can tell the speeds about by the sound..and it's not computer controlled, it's carbed...Any ideas on why? is the cable messed up???
1989 307 RS, soon to be 350.
1995 Red T-Top Camaro, 3.73 gear, F.I.P.K. K&N,Flomaster Cat-Back, Gutted Cat...Killer Stereo (Cerwin Vega and Sony Xplode)
anybody got any ideas?
see that's the thing...i bought this car and it has been turned into a carbed car and a 3 speed auto...but there isn't really a 400 kickdown switch....it's got the cable goin to the carb...the only reason i don't think it's a 350 is because the tranny shop said it was a 400....but the pan looks like a 350 pan, but it doesn't look like it fits the tranny...
oh well guess nobody knows ?????
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If it has a kickdown cable, it's probably a 350, 400's had an electric kickdown with a switch on the gas pedal.
The electric kick down switch must work, and the vacuum modulator must be connected to true vacuum (not timed port) or any other source. If you hold the transmission selector in second gear, you should be able to take it too any rpm without it going to third.
Hope This Helps!!!
Hope This Helps!!!
well ok, say it's a 350 tranny....How to I adjust the shifting points...It's Not Computer Controlled...it has an olds motor in it....and the shift console is from the 700r4 so when i shift below drive, it's in low...i can't get second by using the shifter
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
