How Hard is it to install B&M Megashifter???
Old May 13, 2001 | 11:50 AM
maksik7's Avatar
Hey poeple,
This is a question for people who actually swapped in the Magashifter.
1) How hard is it to install, what do I have to change?
2) Does it improve peformance any?
I would really appreciate a short quick response. Thaanks
-Max
-'86 Trans Am WS6
-305 TPI with 700R4
-All stock until I fix all the problems
Old May 13, 2001 | 01:04 PM
82camaro's Avatar
Car: 82 camaro SC
You have to cut the console(not really that difficult). The rest is bolting it down and hooking everything up. You have better control over shifts. It will only go up or down one gear at a time from 1st - 4th
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
[This message has been edited by 82camaro (edited May 13, 2001).]
Old May 13, 2001 | 02:13 PM
EVILFACE's Avatar
Very easy to install, takes a while to adjust though. Looks sharp and functions well.
EVILFACE
88 Camaro
Stock 305 TBI Auto,Flowmaster, Full 3" Exhaust, B&M Megashifter, K&N Open Element
Runs A Blistering 16.5 @ 81.5 mph
http://www.evilface.com/evilscamaro.htm
Old May 13, 2001 | 02:17 PM
CrazyRob75's Avatar
The install is fairly simple, but TAKE YOUR TIME adjusting the cable. A small adjustment can make a big difference in the way it shifts. I figure most of the complaints are caused by improperly adjusted cables.
85 Berlinetta Iroc exterior NOW 454 powered, 4.10 gears, 275/60/15 Hoosier Quicktimes and a PILE of other goodies..........YES, it's street driven!
check it out at http://www.bsronline.net/members/rob/rob_specs.html
Old May 14, 2001 | 02:03 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I agree; my shifter went in easy, with the hardest part being the cutting of the console top. I cut mine with a cutting tip in a soldering gun. And I also agree with spending a ton of time and care on the adjustment of the shift cable. Make sure to put the shift cable's swivel in the CORRECT hole on the new B&M shift lever.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old May 14, 2001 | 03:05 PM
maksik7's Avatar
What do you mean by cutting the console top? Do you mean, I have to cut up the plastic top of my center console. can this be done with a conventional saw?
Thabks for the help guys
-Max
Old May 14, 2001 | 09:18 PM
Jza's Avatar
Jza
The best way is with a high speed cutoff wheel. I've installed mine and one in a ZZ4 Regal and they were both easy to do. If you use a jigsaw just make sure the piece is held down very well and you're using a fine-toothed blade or it'll catch and snap the piece or take chunks out of it.
Old May 15, 2001 | 01:20 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Measure 50 times, cut once...
Old May 16, 2001 | 12:34 AM
jaretz28's Avatar
Yeah, just careful cut trim off the extra plastic, bolt it in and remember the groment in the floor board! I forgot mine and the cable finally snapped though the plastic from being rubbed on sharp metal.
Anyway, then just bolt her to the gearbox and let her fly.
If you ever do race for money at the track, the reverse lock-out is a must to compete.
camaro11j
Sep 19, 2018 08:49 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
db057
Aug 22, 2015 08:17 PM
crazynights
Aug 21, 2015 06:53 AM
