stupid question but i gotta know
Old May 26, 2001 | 03:00 PM
buddman91rs's Avatar
what do the 2500 stall TC actually do for performance? what type of TC should i get if mine is going bad?
1991 RS LO3
mods: 14" chrome air cleaner, straight-piped after cat exhaust with one chrome dual tip on the left side.
future mods: headers, removing smog equipment, and as many cheap mods as i can find
aol s/n: budman8503
RACECAR spelled backwards is RACECAR
Old May 26, 2001 | 07:39 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
is there really a town called Niceville?
Old May 27, 2001 | 08:40 AM
transfixleo's Avatar
It all depends. If you have a basically stock engine that makes power at @2000 RPM up to @5000, then you will be losing 500 RPM of usable power! If on the other hand you've added headers and a hot cam and now it doesn't make power until @2800 RPM you will have a little bit of a bog, get it? The point is that we hear about stall converters and we think that we should all have one (well we do actually!) but the real point is that we should have the correct stall for the engine setup we have. In the first instance, instead of a higher stall converter, lower gears would be more beneficial (but not too low, it peaks out at 5K remember). The correct stall is one that puts us at (or JUST below) the beginning of our power band.
Old May 27, 2001 | 03:06 PM
johns84bird's Avatar
Car: Pontiac Grand Prix GTP
Engine: 3.8L V6 SuperCharged
I have major bog problems at full throttle with the 700-r4. my setup is an un-modified carbed 350. First gear revs up great (I think due to the deep ratio of the 700-r4 first gear). But the 1-2 shift gives a slight bog and it takes a while to get up to where it makes power again. 2-3 shift and 3-4 shifts are totally horrible, it sounds like the engine and feels like the engine doesnt have enough power to accelerate the car anymore and the rpms are real low. I have a 2.73 rear end (I know thats horrible), but could my TC be part of the problem? I will be modifying my engine a lot this summer so I wont be changing it now (only to have to change it again later). I would just like some insight into this problem... Thanks and sorry I couldnt help you buddman01rs, I guess I have a similar question.
Old May 27, 2001 | 08:42 PM
82camaro's Avatar
Car: 82 camaro SC
Johns84bird: A higher stall converter will help the launch. It's not going to do much of anything for the 1-2 shift(or the other shifts), since you will be above the stall rpm both before and after the shift. Hold it in first gear a little bit longer. Your main problem is those gears.
My advice for anyone getting or wanting a higher stall converter is to get the optimum gears first, most likely 3.42's or 3.73's, and then see if you need a higher stall converter.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
[This message has been edited by 82camaro (edited May 27, 2001).]
Old May 28, 2001 | 01:53 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
<font face="Verdana, Arial" size="2">Originally posted by zenish:
is there really a town called Niceville?</font>
I saw another guy in here from Hell, Michigan.
Old May 28, 2001 | 01:55 AM
AJ_92RS's Avatar
<font face="Verdana, Arial" size="2">Originally posted by transfixleo:
The correct stall is one that puts us at (or JUST below) the beginning of our power band. </font>
Old May 28, 2001 | 01:56 AM
AJ_92RS's Avatar
500 rpm below peak torque is what pro drag guys go for.
Cleotiz
Jan 6, 2018 08:56 PM
3.8TransAM
Sep 3, 2015 06:38 PM
masonta
Sep 1, 2015 06:40 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
