OVERDRIVE VS DRIVE????
Old May 23, 2001 | 02:40 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
WHEN DO I USE OVERDRIVE VS REGULAR DRIVE? IS THERE BETTER GAS MILEAGE USING ONE OVER THE OTHER? SHOULD I FEEL A DIFFERENCE IN DRIVING WHEN USING OVERDRIVE?
86 Camaro Black SS Coupe, T Tops, Flowmaster, Custom Paint, Dunlop Road Kings S/R tires, Wheel Country Directional Chrome Wheels, New Leather seats, new carpet and headliner, complete front end suspension rebuild, new Valve seals, and more mods to come
http://www.angelfire.com/sports/niterider/86camaro.html
Old May 23, 2001 | 03:50 AM
transfixleo's Avatar
As long as the TV cable is set properly you can just leave it in O/D and the tranny will take care of when to use it and not to.
That being said I would recommend for driving below @40 MPH to use the D position. The reason is that onpe of the weak points in the 700 is the input sprag. Not that it is bad, just that by nature, a sprag will wear, sort of like a tire. In O/D, 4th gear the sprag is overrunning and that is when it wears along with when it reengages.
Old May 23, 2001 | 09:55 AM
Axle/Gears: Posi
SO HOW DO I KNOW IF THE TV CABLE IS SET PROPERLY? ALSO HOW DO I KNOW IF THE INPUT SPRAG IS WORN OR WEARING BADLY?
Old May 24, 2001 | 03:41 AM
To adjust the TV Cable skip the book method and do this: Press the D button on the adjuster and loosen the cable setting. Now, have someone floor the gas pedal while you check to see if the throttle plate is open all the way. Usually they are off a little and will wiggle. Do whatever you have to do to get it open solid. Now, with the pedal floored, press the D button and pull the cable back as hard as you can and release the button. You now have the engine, tranny and gas pedal all in sync at WOT. Mark the cable so if for some reason it gets moved you can know where to put it again. The problem with the 'self adjust method' is that it bends things and puts them permanently out of whack. It is also the full TV setting, which is theoretically what the GM method does.
As far as the sprag goes, when the problems start to show up, the test to see if it is bad can wipe out some parts due to them spinning at multiples of engine speed. WHen you kick down from 4th to 3rd the sprag has to reapply under high load. If you experience a rev/bang doing this, STOP! The lower the rear end gearing the quicker the sprag wears.
Old May 24, 2001 | 09:02 AM
birdofprey83's Avatar
Car: 1989 Firebird
Engine: 2.8
<font face="Verdana, Arial" size="2">Originally posted by 86NiteRider:
</font>
is you capslock key broke??
we dont like to be yelled at.
any way, when in town driving I put it in D. when highway driving i use OD. if you not going to be going faster then 45mph leave it in D or you trans will keep trying to shift into OD.
hope this helps
Chuck
I'm not shy, I just
observing my prey.
My Firebird site
Old May 26, 2001 | 11:07 PM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
how do you know your TV Cable is out of adjustment?????????
Old May 27, 2001 | 08:31 AM
It is best to follow the method I posted above if you have any doubts. These parts do tend over time to change due to heat and stress.
Old May 28, 2001 | 01:46 AM
One Eyed Jack's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Ryan_Alswede:
how do you know your TV Cable is out of adjustment?????????</font>
When you get bad reception and baywatch comes in all fuzzy.
1992 Pontiac Firebird (stock)
- 5.0L V8 TBI / Automatic Trans / Every option, excluding leather
- Killer car audio system:
  • Aiwa CDC-MP3 head unit
  • Rockford Fosgate 360a2 amp
  • pair of 12" MTX Thunder 5000s in a custom box
  • Pioneer 3-way 6x9s, soon to add more more more!
Old May 28, 2001 | 02:36 AM
Axle/Gears: Posi
SO IF I AM IN DRIVE AND I SHIFT TO OVER D SHOULD I FEEL SOMETHING? IS ANYTHING NOTICABLE OR DIFFERENT LIKE WHEN YOUR IN A 4 X 4 AND SWITCH TO 2 X 4. THANKS
Old May 28, 2001 | 03:50 AM
You will only feel sometning if you are up to a speed where 4th will come in. Otherwise it will stay in whatever gear you are in.
Old May 28, 2001 | 06:59 PM
HybridZ's Avatar
Car: 13' ZL1/91' Z28/10' Audi A5
Engine: 6.2L SC/5.7L 350/2.0L Turbo Quattro
Transmission: M6/700R4
I usually just keep it in OD. Better gas mileage in OD. As for the rest, its an automatic, it will take care of everything else on its own. But when I want to take off or something I downshift to D and pound it. This usually puts me back into the seat.
SS 17x9.5 wheels,
HOTCHKIS 1"drop springs,
HOTCHKIS tower brace,
Bilstein struts and shocks,
K&N filters,
MSD 6A,
MSD 8.5mm Wires,
MSD Cap & Rotor,
Hypertech airfoil,
SLP intake runner (plennum not ported yet, soon)
High flow cats,
SPOHN panhard bar, lower control arms, and subframe connectors,
Baer front track system,
3" Flowmaster Exhaust System,
2100 Stall High Performance Torque Converter,
300 watt sound system,
and soon to come...ZZ4 crate motor...hopefully.
Old May 28, 2001 | 09:46 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Is the TV Cable supposed to be all the way in or no??
[This message has been edited by IROCZTWENTYGR8 (edited May 28, 2001).]
Old May 28, 2001 | 11:51 PM
Administrator
89 RS
Looking For:
87 IROC-Z28 350 TPI
Old May 29, 2001 | 04:29 AM
Follow the adjustment procedure (as I posted above) to the letter and see what it does.
[This message has been edited by transfixleo (edited May 29, 2001).]
Vintageracer
Jan 10, 2020 05:33 PM
gta90
Sep 15, 2015 04:00 PM
86IROC112
Aug 21, 2015 12:39 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
