Axle Swap...
Old Feb 25, 2009 | 09:22 AM
Meagleson08's Avatar
Car: 1988 Camaro Base
Engine: 305 TBI
Axle/Gears: 2.73:1 Stock.
Axle Swap...
I am wanting to swap my rear end for an Iroc rear end
I currently have a 2.73:1 Gear Ratio....and drum brakes
I am wanting to get a 3's:1 Gear ration with disc brakes but dont know how about going and doing the swap...
Aka...what do i need to replace mine with an iroc's with discs besides a new prop valve?
And yes i have a 4 Link suspension....
Old Feb 25, 2009 | 09:58 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: Axle Swap...
If you have a 4 link you cant swap in a stock rear end out of an iroc without modifying the stock rear end which isnt worth the effort. If your swaping stock rearends for drum to disk all you really need is the valve you metioned.
Old Feb 25, 2009 | 10:00 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Axle Swap...
II currently have a 2.73:1 Gear Ratio....and drum brakes. I am wanting to get a 3's:1 Gear ration with disc brakes but dont know how about going and doing the swap. Aka...what do i need to replace mine with an iroc's with discs besides a new prop valve?
This following sticky should answer most of your questions:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Feb 25, 2009 | 10:15 AM
Engine: 305 TBI
Re: Axle Swap...
Would i need to replace lines for bigger or smaller sizes?....
Old Feb 25, 2009 | 10:32 AM
JamesC's Avatar
Re: Axle Swap...
No.
JamesC
Old Feb 25, 2009 | 10:40 AM
Engine: 305 TBI
Re: Axle Swap...
Thanks...Greatly apprciate all your help/advice
Old Feb 25, 2009 | 10:48 AM
Stephen's Avatar
Car: 87 GTA
Re: Axle Swap...
If you have the stock 3 link (or do you really have a modified 4-link, on a 305 TBI car?) then it is a direct swap...no mods NEEDED, although some will say you "need" to swap master cylinders, many successful swaps will prove you don't NEED to.
Old Feb 25, 2009 | 11:00 AM
JamesC's Avatar
Re: Axle Swap...
I'm unsure that "prove" is the correct word. While the new rear may work without swapping the proportioning valve, for best performance, I'd suggest, as I do in the sticky, to use the proper valve. Hey, the valves are different for a reason.
JamesC
Old Feb 25, 2009 | 11:59 AM
big gear head's Avatar
Re: Axle Swap...
Just exactly what kind of suspension do you have? If you have an after market suspension then why mess with a weak 3rd gen rear end at all? Why not go with something stronger and just swap the disc brakes onto it? You could use a SS Impala 8.5 10 bolt or a second gen Camaro 8.5, or many others.
Old Feb 25, 2009 | 01:21 PM
Saber's Avatar
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
Re: Axle Swap...
Yes im curious to see what kind of suspension you have, if you have 4 link why do you have 2.73S???
Old Feb 25, 2009 | 10:18 PM
Engine: 305 TBI
Re: Axle Swap...
Sorry guess i got my factwrong lol..its a "3 link"
sorry about that...
Its the stock config otherwise iw ouldnt look twords down grading if it was aftermarket lol
Id like to replace everything Torque arm, pan hard, lower controls...everything some day..but all those parts start at $200 and go up lol...
But Yes..It's the stock "3 link"... sorry about the confusion
cheesehomer
Dec 31, 2015 08:48 AM
bigjay89gta
Oct 15, 2015 08:04 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
usafirebird
Sep 29, 2015 11:58 PM
Gordonr1973
Sep 29, 2015 11:59 AM
