92 rs wc td reverse what is that :(
Old Mar 12, 2009 | 01:00 PM
yetterben's Avatar
Bought the car fixing its gremlins. Anyway there is no reverse. Put it in reverse let out clutch pops right away. Hold it in revers just grinds. Ideas?
sorry about title it is a wc t5
Old Mar 12, 2009 | 01:20 PM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: 92 rs wc td reverse what is that :(
The fork is bent, the pads are worn/missing, the engagement slider teeth, or the gear engagement teeth are trashed. You'll need a rebuild either way, so once the trans is opened up, you'll know for sure.
Old Mar 16, 2009 | 08:54 PM
yetterben's Avatar
Difficulty level involved here. never ripped open a trans rebuilt a few motors never a trans. Any good websites for parts or rebuild pics.
Old Mar 17, 2009 | 12:30 AM
yetterben's Avatar
also some times it will work for a few feet.
Old Mar 17, 2009 | 06:20 AM
85MikeTPI's Avatar
You need a few "speciallized" tools, but it's not rocket science. Large snap-ring pliers, bearing splitter/press (or local shop), dial-caliper or depth-micrometer.
The service manual is here: http://www.ttcautomotive.com/English...0-0199_173.pdf
When I did my first one, it probably took 2x 1/2-days with the manual sitting in front of me step-by-step.
Old Mar 17, 2009 | 09:23 AM
yetterben's Avatar
Thanks i have not checked if i have 5th yet but all the posts about that plug on the drivers make it sound like they cant even get into reverse. Was thinking it might be that but guess not.
Old Mar 17, 2009 | 03:49 PM
yetterben's Avatar
Internal pics would rock if anyone has them so i can see what i am looking for.
Old Mar 17, 2009 | 05:14 PM
85MikeTPI's Avatar
Here's some pics of a rebuild I did a while ago. What is it you're looking for?
http://www.eecis.udel.edu/~davis/z28...5rebuilds_web/
This is actually a Mustang unit.
Old Mar 20, 2009 | 06:24 PM
yetterben's Avatar
Like where i should be looking inside once i get it out and open.
F-body driver
Mar 6, 2023 11:44 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
Veaceonee
Sep 29, 2016 08:15 PM
nova983
European Region
Nov 2, 2015 12:15 PM
84redta
Sep 19, 2015 09:58 AM
