looking for better gears
Old Mar 13, 2009 | 04:39 PM
joejoe187's Avatar
Car: 1986 Trans am
Engine: 383 stroker
Transmission: 5 speed
Axle/Gears: 373
I have a 1986 Trans am. I took the 305 out and put in a 383 stroker. the stock rear was not giving me the pull i wanted with the amount of horse power I had in my new engine. I have the 9 bolt inspection plate rear end, from what i understand it the borg warner. I have been told i can only get 373 gears for this rear end, which is fine with me thats the gears i was looking for. Ive been told this rear end is stronger then the 10 bolt chevy. Can anyone give me some in site on this? thanks Joe
Old Mar 13, 2009 | 05:00 PM
big gear head's Avatar
Re: looking for better gears
If you have the 2.77 gears then you will have to replace the differential too. The 3.73 won't fit the 2 series that goes with the 2.77. If you have 3.27 or 3.45 gears then all you need is a 3.73 gear and a good installation kit. Do you have disc brakes?
Old Mar 13, 2009 | 06:48 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Randy's has new 3.73:1 gearsets at a great price. while you're in there, your limited slip is probably worn out.
Old Mar 13, 2009 | 07:41 PM
joejoe187's Avatar
Car: 1986 Trans am
Engine: 383 stroker
Axle/Gears: 373
I have the 4 wheel disk brakes, as far as i know my car with the 5 speed came with 323, my friendmjust put a **** brake rear end on his 89 Z28, it has 277. he just told me he needs a spacer to make he 373s work. 277 only came in the automatics as far as i know
Old Mar 13, 2009 | 07:48 PM
joejoe187's Avatar
Car: 1986 Trans am
Engine: 383 stroker
Axle/Gears: 373
how do i look at randys deals?
Old Mar 13, 2009 | 08:08 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
www.ringpinion.com If your posi is worn anyway, better to get a 3 series posi than use a spacer, but the spacer is cheaper. That's all that can be said for it.
Old Mar 13, 2009 | 08:26 PM
blackroc68's Avatar
YOU can get 323,345.390
Old Mar 13, 2009 | 09:23 PM
I'm a WD for Randy's. If you need information on parts let me know.
Old Mar 13, 2009 | 10:01 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
https://www.thirdgen.org/forums/faq-...now-about.html
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
