Looking for input on going posi
Old Mar 18, 2009 | 12:02 AM
Kwijybow's Avatar
Car: 1987 Z28 Camaro (T-tops)
Engine: Carb'd 305
Transmission: 700R4 (auto)
Axle/Gears: Posi / 3.27
I want to buy a posi upgrade for my car. I've found this one on ebay...
http://cgi.ebay.ca/GM-TRACLOK-DIFFER...ts_Accessories
...would it work with my rear end? Is there anything I should know before buying?
Old Mar 18, 2009 | 06:52 AM
big gear head's Avatar
Re: Looking for input on going posi
That isn't a TracLock, it's an Auburn. I would pass on it. The Auburn wears out fairly quick and is not rebuildable. The Eaton is a much better differential. It will last MUCH longer than an Auburn and it's rebuildable if it ever does wear out. You can also tune the Eaton to fit your needs.
Old Mar 18, 2009 | 07:46 AM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Have you considered or looked into a (used) rear end swap instead? No special tools or set up required.
Old Mar 18, 2009 | 10:39 AM
Kwijybow's Avatar
Engine: Carb'd 305
I'd appriciate some links to an Eaton posi LSD if anyone has any. Must have shipping to Canada.
Old Mar 18, 2009 | 11:58 AM
http://www.eaton.com/EatonCom/Produc...iLSD/index.htm
Old Mar 27, 2009 | 03:41 PM
Kwijybow's Avatar
Engine: Carb'd 305
Ok, so I've been looking up eaton diffs but I still don't really know what I need. Would my car have a 9 or 10 bolt rear? How do I find out? Do the lsd's have to support my car or are they universal parts? Would something like this one work in my car?
http://cgi.ebay.ca/GM-8-5-Eaton-10-B...1%7C240%3A1318
Old Mar 27, 2009 | 11:45 PM
Nope, that's a Governor Lock for the 8.5 rear end. It's for the wrong rear end and you don't want a Governor Lock. You need an Eaton Posi for the 7.5 10 bolt with 26 splines. If you want to keep the 2.73 gears then forget about the Eaton Posi. They are only available in 3 series, which won't work with your 2.73 gears.
Old Mar 27, 2009 | 11:51 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
"big" you have a very sick ride.
Old Mar 28, 2009 | 06:40 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Some general info may be helpful:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Mar 28, 2009 | 11:45 AM
Thakn you Tony.
KO1
16
Oct 15, 2015 05:00 PM
Linson
Oct 1, 2015 09:50 PM
