governor ?'s
Old Jun 25, 2001 | 05:43 PM
86_327_camaro's Avatar
governor ?'s
ive got a 700r out of an 89 p/u. should i redo the governor or leave it as is?
Old Jun 26, 2001 | 05:49 PM
anyone?
Old Jun 27, 2001 | 05:03 AM
transfixleo's Avatar
Um... What are you after?
Old Jun 27, 2001 | 05:54 AM
Jay 727's Avatar
Well,,, you could pop the cover off and check it's gear. If you are replacing another 700 with this one I would use the governor that came with the vehicle that the trans is going into. If none of these apply to what you are doing just install the trans and see what happens, part throttle shifts and WOT shifts at the wrong time can either be the governor calibration or the t.v. cable adjustment/pull rate.
HikoriYami
Sep 21, 2015 07:11 PM
crazynights
Aug 21, 2015 06:53 AM
88transam5.0
May 3, 2002 10:07 AM
EDDIETA_ZZ3
Jul 5, 2001 05:59 AM
92Z
Feb 16, 2001 11:03 PM
