how many people here are not runing a clutch safety switch?
Old Apr 6, 2009 | 06:45 PM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
how many pple here are not runing a clutch safety switch? i did the auto to t56 swap, i am considering leaving not hooked up. anyone here have a bad experience?
Old Apr 7, 2009 | 08:10 AM
JPhillis's Avatar
Car: 1992 Camaro
Engine: 350 .030 over 298 cam 9.1 Flat tops
Transmission: T5 swap complete
Axle/Gears: 3.73 posi the 4.10s are history
re: how many people here are not runing a clutch safety switch?
I dont run one since NOBODY else drives my car but ME...
Old Apr 7, 2009 | 01:55 PM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: how many people here are not runing a clutch safety switch?
Natural Selection has already taken care of everyone not running a clutch safety switch.
Old Apr 7, 2009 | 02:05 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Plus if you go to a track of any kind....they are supposed to check it and you won't pass tech...that's the first thing they check at our tracks...
Old Apr 7, 2009 | 02:10 PM
JPhillis's Avatar
Car: 1992 Camaro
If people are that stupid and are not smart enough to push the damn clutch in before they start the damn car guess what.....THEY HAVE NO BUSINESS DRIVING A MANUAL TRANS. Some cars were built all the way up to the late 80's with out clutch safety switches. I know 1987 for sure.
Old Apr 7, 2009 | 05:06 PM
Stevo's Avatar
Car: Pair of 92 Z28s
Your right cause that one time you forget or your mom gets in your car or your friend or your 8 year old sister decides it would be fun to play with your keys and turns the car over while its in first gear and has it jump forward and crashes into someone or something and does serious damage to your car i guess that's worth it to you. It's a safety feature, use it.
Seriously its like 2 wires, wire it up and keep it. You must have it to run legally at any track.
I can't think of any car for that matter that i have hopped into and it didn't have a clutch safety switch. Including my dads 69 GTO...i find it hard to believe any car made after then came without one from the factory.
Old Apr 7, 2009 | 09:24 PM
Abubaca's Avatar
Wow, tough crowd.
Should you use one, yes. Why NOT use it??? Better safe than sorry.
....but the holier than thou crowd needs to relax a little. Safety? Really? Come on, you take more risks walking across the street.
Old Apr 7, 2009 | 09:47 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Originally Posted by Abubaca
Wow, tough crowd... the holier than thou crowd needs to relax a little. Safety? Really? Come on, you take more risks walking across the street.
Ya no kidding... lighten up guys. Its not really THAT big a deal if he doesn't hook it up. Sure he won't pass tech at any dragstrip, but if he doesn't care, then I don't see a problem.
I had nothing but problems with the switch in my '83 for 4 years, so I just took it out, spliced the wires together, just to be done with it. Couldn't be happier.
Old Apr 8, 2009 | 07:37 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
I'm not running one either since I had problems with it too. I probably should wire it up like others have said, but it's one of those minor things that takes me forever to get around to. To the OP, if you're still working on the swap, it's best just to wire it up now, or like me, it'll never get done.
Old Apr 8, 2009 | 07:52 AM
GICATA's Avatar
Car: '83 WS6 T/A 65,000 miles
Engine: 5.0L vin H stock, 406SBC right now
Axle/Gears: Corp. 3.73
Probably should have it installed and functioning on my car...but nobody touches my car anyway.
Professionally, I've replaced them as it was part of my safety inspection routine.
Old Apr 8, 2009 | 08:10 AM
JPhillis's Avatar
Car: 1992 Camaro
How many states really have saftey inspection as a yearly process? I am curious to know. GICATA I am with ya. My car sits in a garage with the doors locked and the garage locked up tight and I have the only key. The wife and kids have no business in the garage anyway that is my domain and they know it.
Old Apr 8, 2009 | 08:25 AM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Yea, some saabs didn't have them up to close into the 90's. I can't remember the year exactly, but i couldn't figure out their "you have to be in reverse key lockout," and as i was moving the key fowards and back to try and get it out of the ignition, the car jolted fowards. I fortunately reacted quickly and had my foot on the brake to begin with, but they are out there.
Another thing to think about is yes, what if someone gets in your car unaware, and causes an accident. I could see the law trying to come down on you for "liability" of tampering with an existing safety feature or your insurance company not covering damages for some stupid reason. To each their own, just be responsible and make sure noone unaware gets in your car.
Old Apr 8, 2009 | 08:32 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Of all the times I've been to the track there was never a check for a clutch safety switch.
Then again GM never installed them on '67s.
And starting an engine with the clutch pedal down is murder on the thrust bearing. No oil pressure and all that.
Only need to check that the stick is in neutral before turning the key.
RBob.
Old Apr 8, 2009 | 10:51 AM
Engine: L98 494hp
RBob.
It may be that your car is old enough where they dont check but where i'm at they check both manuals for clutch switch and the neutral safety switch for autos..
Old Apr 8, 2009 | 12:58 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Seems every track is different. No check of the park/neutral safety switch on the '92 with the auto.
RBob.
Old Apr 8, 2009 | 01:40 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
guilty..
i dont run one.. but i always drop it in neutral first and start with the clutch in anyway.. i did have it jump one.. i was adjusting valves.. thank god i didnt have the remote start switch.. jumped about a foot forward and scared the crap out of me..
Old Apr 9, 2009 | 09:56 AM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
No european or jap cars over here have ever had any safety starter lockout switch afaik..
But then most cars here are manuals, and the lawsuit thing isn't so bad here either.
If the engine stops for any reason you can always get the car off the road by "starting" it in 1st or 2nd, clutch out..
Street Lethal
Apr 30, 2019 12:14 PM
Ducati900ss
Sep 2, 2015 09:05 AM
87 camaro iroc
Aug 20, 2015 07:47 AM
Bryan F
Aug 18, 2015 02:28 PM
rsrmoore
Aug 7, 2015 08:44 PM
