Hot in here... or just me?
Old Jul 5, 2001 | 05:45 PM
85firechicken's Avatar
I'm new to driving thirdgens in summer, so is it normal to feel like someone's aiming twin hairdryers set on high heat at me from under my console? I think I'm going to melt!!! I think my tranny's running hot, but the fluid is fine, and it was JUST rebuilt. Any ideas? or is it normal?
1985 Trans-Am: GM Goodwrench 350 (basically stock except for the heads); Newly rebuilt 700R4 w/B&M Shift Kit; B&M Ratchet Shifter; Holley 750; Edlebrock Performer RPM Intake; Hooker Competition Headers; MSD Ignition; K&N filters everywhere; Whatever gear ratios came stock with the 85 T/A (it at least has Posi); Maybe some other mods that I just haven't noticed (I just bought it in Feb '01); T-Tops; work in progress...
Old Jul 5, 2001 | 06:41 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
If you are feeling that much heat coming from your trans I would invest in a tranny cooler, especially since you just had it rebuilt. To answer your question I don't feel any heat coming from mine. But then again I have a tranny cooler.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
2:73 GEARS
Rebuilt 700R4, with manual valve body
B&M Megashifter
Soon to be installed
Exhaust Cut-Out and different gears, either 3:73 or 3:42
"There is nothing more addicting than speed"
Old Jul 5, 2001 | 08:36 PM
Ragin'87's Avatar
the 87 sent quite a bit of heat through the tranny tunnel.. not sure if that helps. but it did.
ANthony
previous ride: 87 Camaro LT
350, A4.Comp Cams 268H, Edelbrock Preformer intake, Hedman Headers and y-pipe, gutted cat, No AIR/smog pump. 14x3" Open element K&N, Q-jet w/ D hanger and DA rods, adjusted AV spring tension and quick can.
Current ride: 1992 Camaro RS, K&N, Flowmaster, 305, T5, Black, T-tops, 76k miles.
Old Jul 6, 2001 | 01:36 AM
Bort62's Avatar
My tranny Tunnel gets Hot as hell, My entire Car is an oven.
Thats what TTops are For.
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver 14.82 @ 91.1 (faster than Ed)
Reader's ride -> My Ride
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old Jul 6, 2001 | 02:32 AM
bubbz89's Avatar
Car: 1990 RS
Transmission: TH-350
god bless a/c.
Old Jul 8, 2001 | 01:14 AM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
these cars are hot,t-tops can be inconvenient,I'd like toi run my ac if i can get it working,a tranny cooler would be a good idea too. try leaving your vents on and keep moving,those t-tops are like solar panels in traffic...
Old Jul 14, 2001 | 01:47 AM
irocdaddy's Avatar
Car: 89 iroc,2012 eco 150,roadglide
Engine: zz4
Transmission: t56
The heat you probably are feeling is the "chevrolet engineered circulating air system" I read here that there is a natural stream of air (hot from under the hood somewhere) that comes from under the dash. The air is only felt when the car is moving. Hot as hell I hate it!
89 iroc,zz4/700r4/3:70 gears/koni yellows/herb adams bars/and alot of other crap to make it work!
Old Jul 23, 2001 | 05:58 PM
simon's Avatar
I have the same exact problem. Does any have any idea how to get around this. I have noticed that there are two vents on either side of the center console near the front. No air comes out of these when the A/C or fan is off, but when you drive down the road air starts to come out of them and increases with vehicle speed. The air itself only seems moderately warm, but its as if it pulls the radiant heat from the firewall right into your legs, and as hot air rises it eventually fills the cabin. I also notice that with the A/C on the air coming out from the same vents is cold. I should mention I have an 89 RS, but I've noticed the same ducts in an 88 Z28 as well. Does anyone have a clue as to how to solve this? One more thing, for those of you who have changed you own heater core: remember that flap or door near the heater core? It is actuated by the lower slide lever - the one that adjust from hot to cold.
Apparently GM used some sort of foam in an effort so seal the duct off from the heater core. Over time the material degrades and crumbles. I think this creates a gap that enables some of the radiant heat from the core to escape and come into the cabin. When the windows are down it creates a vacuum and pulls the air through the core even without the blower on. Does this make sense to anyone? I guess I could try to replace the foam but I'm not in a hurry to rip apart my whole dash and console again.
89 RS 305 TBI,Ultimate TBI Mods,2.73 G80 rear,Open element,Flowmaster exhaust.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Thaney9
Oct 24, 2015 07:26 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
mfp189
Sep 27, 2015 09:25 AM
ironbmt
Sep 27, 2015 06:00 AM
