CORVETTE SERVO ?
Old Jul 28, 2001 | 12:37 AM
steveclk's Avatar
CORVETTE SERVO ?
Hi ,I would like to know what the corvette servo does when you install it in a 89 trans am ,are there any benefits in the swap , or is it just a waste of time and money.Several people told me to swap in the vette servo but they can't seem to tell me what it does.Please someone explain it to me .
Thanks. (been to some sites but all they say is how to install it no explanation on what it does)
Old Jul 28, 2001 | 04:51 AM
transfixleo's Avatar
The 'Vette servo (which you might already have) has the largest second apply diameter made by GM. This increases holding power in second, and makes for a firmer 1-2 and 2-3 (due to slower release on 2-3).
The REAL reason GM came out with it was to address a 2-3 cutloose (engine flare on the shift), therefore the above mentioned slower 2-3 band release makes up for it.
I prefer to only use it where it is needed, IE, truely high power cars, not your usual 250 HP at the flywheel jobs that people THINK have more power.
Old Jul 28, 2001 | 06:38 PM
steveclk's Avatar
<font face="Verdana, Arial" size="2">Originally posted by transfixleo:
</font>
Thanks now I understand what it does .
Old Jul 29, 2001 | 10:09 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
how do you determine if your tranny allready has the vette servo ?
92Z28
89GTA
Old Jul 30, 2001 | 04:16 AM
Take the Servo out. The 'Vette Servo has the last three numbers "093" cast into it while the regular V-8 is "553" and the never use Servo is "554".
Old Jul 30, 2001 | 07:37 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
Thanks for the help
92Z28
89GTA
Old Aug 2, 2001 | 10:34 PM
kingtaling's Avatar
Uh oh. Mine says 554. Does that mean i should never use it again? or should it never have been used in the first place? or should the people never use it to build my tranny which they did and thats why it doesnt work? or does it mean they never used that number? what? i dont get it. maybe it just doesnt exist, this is all a bad dream. yeah thats it.
Old Aug 3, 2001 | 12:20 AM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
I think the "554" is the NON performance version.
92Z28
89GTA
Old Aug 3, 2001 | 03:33 AM
The 554 should not be used in anything but a low output V-6 (I don't use themon anything and neither do any knowledgeable builders). GM put these in allot of V-8's though trying to get a compromise on shift quality concerns at various throttle positions. For most aplications the 553 is the one to use. If you have a true high power application then go for the 093.
Old Aug 3, 2001 | 06:05 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Maybe this will help you understand: 2-4 Servo ID
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
the_hamturdler
Sep 30, 2015 12:50 PM
dusterbd
Sep 29, 2015 08:40 AM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
Dragonsys
Sep 25, 2015 03:51 PM
italiano67
Sep 22, 2015 08:42 AM
