Help QUICK!!!!!!! Anyone heard anything Bad about richmond gears?
Old Aug 8, 2001 | 11:57 PM
RED89GTA's Avatar
Has anyone had any problems or situations with there Richmond gear? I have an 89 GTA im gonna stick a 3:73 in, I know they whine a little but, do they hold up ok? any help would be appreciated!!!!!
Old Aug 9, 2001 | 12:02 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
They are prolly the best replacement gears on the market. Make sure to get street gears as the high nickel drag race gears wear too fast.
Old Aug 9, 2001 | 05:58 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
They are made exactly for what you probably plan to do with them (racing) so you shouldn't have any problems. Most premature failures can be traced back to improper setup/break-in so make sure you follow the directions VERY CAREFULLY and fill out the warranty card. I have had no problems w/ mine, nor do I know anybody personally that has either. Good luck.
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
Old Aug 9, 2001 | 08:19 AM
Mark W. Winning's Avatar
I have had Rickmonds in my 9" for 6 years now. No Problems and low noise too!
1992 Pontiac Firebird 350/Six Speed
1987 Toyota Pickup 383/500+ HP
Old Aug 9, 2001 | 09:40 AM
RED89GTA's Avatar
How long is Break in?
Old Aug 9, 2001 | 09:43 AM
Ant87IROC's Avatar
Car: 87 IROC Z28
Transmission: TH700R4
I have the richmond 3.73's in my car, they were really noisy at first, then as they broke in they quited down alot... still a little noisy, but they are holding up nice!
Ant
87 IROC 305 TPI
Old Aug 9, 2001 | 09:21 PM
82camaro's Avatar
Car: 82 camaro SC
My 3.73's have always been pretty quiet. Like they said, break-in and set-up is critical. The instructions have the break-in procedure. It amounts to driving it a little bit, let it cool off, and repeat.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
Old Aug 14, 2001 | 01:14 PM
OldGunner's Avatar
I have Richmond 4:10 ring and pinion in my 70 Chevelle and they work fine. Even with 350 + Hp. I bang on em pretty hard and this is almost a 4000# car. Never had any noise either. I did not install them myself though I had a N/W Differential do the install. If your not familiar with this swap I would suggest having the pro's do it.
mustangman65_79
Apr 14, 2017 05:37 PM
crazynights
Aug 21, 2015 06:53 AM
89fast5oh
Aug 20, 2015 08:34 AM
