How much for rearend gear installation???
Old 08-27-2001, 02:34 PM
IROCME's Avatar
Car: 1986 IROCZ
Engine: LB9....rebuilding coming soon
Transmission: rebuilt 700R4
I am replacing the whining 2:73's out back with 3:42's what would an average trans shop charge for this surgery???
Drive it like you stole it
Old 08-27-2001, 04:42 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I would guess around $500 at least with an increase if you have disc brakes on the rear. Are you planning on buying the gears, if not then add the price of gears and you'll also need an installation kit which is around $100. I just had gears installed by a local guy that my brother knows, only charged me $150, so you're best bet would be to find another place than a shop.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER, NO CAT
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
3:73 Posi
Rebuilt 700R4 vette servo and .500 boost valve
B&M Megashifter, 5" Autometer Tach w/shift lite
Soon to be installed
3" Hooker Aero Chamber
Old 08-27-2001, 07:57 PM
ede
ede's Avatar
i'd guess the flat rate is around 4 hours
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old 08-27-2001, 08:11 PM
colincamaro's Avatar
having my 273 s swapped with 342 s tommorrow
,everywere I called was $650. Getting mine done for $700 with axle bearings
89 RS 305 TBI/Hooker catback
Old 08-31-2001, 05:59 PM
RICHRAD's Avatar
Guys, Guys!! No way! Go to your local automotive machine shop or performance engine shop and ask who the local shadetree gear man is. Installs should never run more than $100- $200.
Old 08-31-2001, 06:25 PM
custman87T/A's Avatar
Just had mine done. $225 for gears $100 install kit and $200 labor. Figure $500 to $700 for total job and parts.
87 Black on Black T/A
T-Tops Digital dash
5.0 TPI S/R Torquer 305 heads Summit TPI cam
204/214 @.050 .420/.442
SLP headers and catback
A4 with 3.42 gears
Fully loaded and everything usually works.
Old 08-31-2001, 11:48 PM
91'firebrd's Avatar
A few years ago I had my 3.23's swapped out for 3.73's and had a take out posi from a 4th gen put in at the same time. Bought all the parts and paid $100 labor. He called in about 2 hours said he was done. That was after he took it out for a test to see if he could hear any whine.
Try to find a mech who specializes in doing gears. The guy that did mine does gears for everyone at a local race track.
Old 09-01-2001, 03:35 AM
89RagTopRS's Avatar
Car: 89 Camaro RS Convertible
Transmission: NWC T-5
I gave my guy a case of beer and $125 to install my gears. I originally planned to install them but I didn't have the knowledge to set them up completely so I had him install them and I bolted the rear back on.
hectre13
12-11-2023 08:14 AM
Nervous2
LSX and LTX Parts
03-10-2016 09:49 PM
hectre13
08-26-2015 08:17 AM
86White_T/A305
08-17-2015 12:16 AM
dhonda200
08-11-2015 11:50 PM
Quick Reply: How much for rearend gear installation???
