t5 install problems
Old Jun 2, 2009 | 10:05 PM
dieselman887's Avatar
t5 install problems
in the process of swapping over my car to a 5 speed. i installed the flywheel and pressure plate and the allignment tool slid in and out with ease. when i got the transmission in and tightened it up the transmission bounded up and it took some effort to turn the output shaft with the drive shaft in it. when i lossened it up the bind went away. what would cause it to bind up with it tighten down?
Old Jun 3, 2009 | 09:45 AM
Jeff91RS's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: World Class T-5
Axle/Gears: 3.27 9-Bolt LSD
Re: t5 install problems
Was your pilot bearing installed correctly? If it isn't straight it will bind up. Probably a stupid question but I have to ask...Was the trans in gear? Just to make sure u weren't trying to turn a motor along with the trans?
Old Jun 3, 2009 | 12:54 PM
vbMike's Avatar
Car: 1987 Camaro IROC-Z28
Engine: TPI 350ci L98
Transmission: T56 - Hurst Shifter
Axle/Gears: BW - 3.70
Alignment tools work but are not great. It was probably slightly out of alignment causing it to bind. As soon as you depress the clutch the mis alignment should correct itself as long as you didn't damage the piolt bearing by tighting down the trans when it wasn't aligned properly.
Old Jun 3, 2009 | 04:01 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
did the trans slide all the way in or did you pull it together with the bolts? if so, you probably damaged the pilot and or clutch disc.
Or, as somebody else mentioned, try pushing the clutch pedal in and see what happens.
Old Jun 3, 2009 | 11:24 PM
it was real tight going in, and when i tightend it down the last little bit it would bind up, but would free up when it was loosened. pilot bearing is in correct. im gonna take it apart and remove the pilot bearing. its the only thing i could think that would bind it up. its like it needs a shim or something. its aggravating me
Old Jun 4, 2009 | 08:50 AM
vbMike's Avatar
When I aligned my clutch I used my hands more than the tool. I stuck the tool in but the disc wanted to sag so I just made sure the disc was centered on the flywheel on all sides using my hands while I tightened the bolts down. The trans should mate flush with the bell housing without having to draw it in with the bolts if it is lined up correctly.
Old Jun 4, 2009 | 10:05 AM
so i should try to re-allign the clutch?
Old Jun 4, 2009 | 10:37 AM
vbMike's Avatar
I'd say take the clutch back off and inspect the piolt bearing to make sure you didn't damage it and that it still spins freely. Then realign/install the clutch. Then make sure the tranny mates flush to the bellhousing before putting the bolts in.
Old Jun 4, 2009 | 10:24 PM
it isnt a roller bearing its more of a bushing, its solid. im gonna try that, it sounds like it would fix it. thanks
rocn7roc
Sep 21, 2021 02:16 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Fronzizzle
Aug 17, 2015 02:52 PM
TheJoeY88
Aug 13, 2015 06:51 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
