which is better? auto to manual, or shift kit?
Car: 98 Z28
Engine: 346 LS1
Transmission: 6 spd.
Axle/Gears: Ford 9" 4.11
You may have read my recent post about trans trouble with my 700r4, I was contemplating on what I should do. I was looking toward a six speed tranny, but I don't know how hard this is going to be to install in a factory automatic. Which would be better and which would be easier, a good rebuild and shift kit for my auto, or install a 6 spd? What do u think?
From: First one out of liberty city, burn it to the ground
depends.. i do lots of city driving.. lots.. and im getting tired of the manual a little.. constant shifting is annoying!
1974 Nova
350 w/ dress up items, B&M Starshifter, Flowmaster 40 series mufflers, Weld rims.
Stereo:
Pioneer Premier head unit, 2 12" pioneer subs run by orion mono amps.
In Memory of #3 Dale Earnhardt
1974 Nova
Stereo:
i have this same concern...fortunatly i havnt put too much money into my car, so i can either just buy a nice tranny, put shift gear in there if i need, and then sell the sob, once its got some mods to it, for way more thani paid for it (find someone lazy) and buy a manual, and just beef that up...but i love my car, and i cant beat manuals =( heh, should get one of those transmission reprogramming kits, might help ya.
Car: 1989 IROC-Z
Engine: 350 Vortech Supercharged ZZ4 TPI
Auto is better for racing and traffic.
Manual is more fun when you want it there.
Time to choose which is more important to YOU.
1989 Chevrolet Camaro IROC-Z
L98 - 350c.i. TPI, rebuilt 700R4 auto w/shift kit, Dual catalyst Monza PaceSetter Cat-Back, SLP 1 5/8 Coated Headers, 3.23 Posi rear, Hypertech chip with 160stat, MSD 6A, Under-Drive pulleys, AFPR, K&N's, !Air Box w/ Ram Air, moddified MAF, !TB Coolant, Spohn Dual Cat SubFrame Connectors, Alarm, Keyless entry, remote starter, 92 Z28 AeroWing, Brand New Paint (6/21/01)
Future: ZZ4 TPI w/EGR, T56, 3.42 or 3.73, Spohn strut tower brace and LCA's, Accell 24# injectors
1989 Chevrolet Celebrity Eurosport <--DEAD AS OF 9/20/01
2.8 MPFI, no mods
225,000 miles and still ticking!
More info and pics on my webpage:http://go.to/iroc-z
AOL IMer: GPA 0point0
2.8 MPFI, no mods
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Simple. How many times has your auto missed gears? Manuals ar emore efficient but they require good shift timing and skill, autos shift right every time, so they are more consistent. Plus, auto's multiply torque off the line where you need it and you can get a higher stall converter to launch with more power. An auto will last longer racing, because you will go through clutches very fast dropping the clutch at 3000 rpm. For drag racing, I would take an auto over a standard any day.
1983 Firebird
TH700R4 Auto
Small Block 400
LG4 ECM, Intake, Carb, Distributor, etc.
Soon to be non-computer.
Clarion Head Unit 45X4
2 Pioneer 400W 12" Subs
Third Gen Performance
"A four cylinder is half an engine."
"Ponies can run, but birds can fly..."
1983 Firebird
TH700R4 Auto
Small Block 400
Car: 82 camaro SC
What Ward said. Having a properly built 700r4 with a shift kit is way more fun and works alot better than the stock 700r4 you already have. Both auto and manual have advantages, but don't compare your sloppy 7004 with a manual--thats an a easy choice.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
82camaro
Car: 1989 IROC
If you are a good shifter, then manual is much better for racing. The auto robs more horsepower in drivetrain loss than the manual. The manual also has closer gear ratios as opposed the the 700 R4's very big drop from 1st to 2nd. That is whay most top times with newer camaros are done with the six speed, rather than the auto tranny.
Tim
Tim
Car: 1989 IROC-Z
Yes, Ward is correct.
If you know how to drive, a manual can be just as good as an auto if not better. However, that if at the begginning of the previous sentence is a very big IF!
Even IF you do know how to drive that well, an auto will be more consistent. Autos dont miss gears and there is no error in clutch work.
Car: 1988 Firebird Formula
Axle/Gears: 3.45
<font face="Verdana, Arial" size="2">Originally posted by L98IROCZ89:
</font>
</font>
Jess
Axle/Gears: 3.45, 3.27, 3.27
Swapped in a WC-T5. The car has a completely different personality now. I love it.
90 RS Convertible
Owner: Top-Down Solutions
(626)369-0040
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
90 RS Convertible
(626)369-0040
Car: 98 Z28
Engine: 346 LS1
i'm still debating this one, I like to shift my own fears and I'm pretty good at it, but I'm thinking it will be a lot of hassle and money to put a manual in an original auto car. I can live without the manual so I'm leaning a little more towards the shift kit auto. Which is the best shift kit, and what results have u guys had in yours?
dhonda200
Aug 11, 2015 11:50 PM
