posi???
Old Jul 18, 2009 | 02:37 PM
mongoosekeith's Avatar
posi???
Ok i have an 88 rs and was wondering if i have a posi rear end. The code on the passenger side of the axel shaft is LC2122 can anyone decifer this for me?
in advance thanks
Keith
Old Jul 18, 2009 | 02:43 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: posi???
in advance thanks
Keith
get both rear wheels off the ground and turn one, if t he other turns in the same direction you got posi (LSD) , or the the cover off and look for clutches in the carier
Old Jul 18, 2009 | 04:17 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: posi???
Check the info in the following link:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Jul 18, 2009 | 09:12 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: posi???
Keep in mind that having a posi rear and having one that actually works are two different things on the 3rd gen.
Old Jul 19, 2009 | 06:20 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: posi???
Most RS models did not have a Limited Slip (G80). It was a option that had to be special ordered in most cases on all RS models. Check your RPO list under the consol lid.
Old Jul 19, 2009 | 03:01 PM
89RS_82Z's Avatar
Re: posi???
wait, 88 would of been an SC not a RS
anyway i knew someone that had a 88 SC with the factory LSD
Old Jul 19, 2009 | 03:52 PM
stroked_n_blown's Avatar
Car: '92 Camaro RS
Engine: 305 TBI
Transmission: Richmond Gear street 5 speed
Re: posi???
6HT
2.73
Posi
6HE
2.73
Posi
6HP
2.73
Std
6HB
3.08
Posi
6HF
3.08
Posi
6HK
3.08
Std
6HL
3.42
Std
6HQ
3.23
Posi
6HJ
3.23
Posi
these are the rear axle codes for an 1988. I looked at the codes for all years and couldn't find the one you posted. Here is a link to all of them
http://www.sethirdgen.org/reardata.htm
Not sure if you are looking at the right numbers or not. As you can see all the codes start with a number; mine for example is 2PM C169 2 making it a posi rearend from a 1990-1992 vehicle ( unfortunately the previous owner had swapped in 4:10 gears which are hell with my Richmond Gear 5 speed).
Old Jul 19, 2009 | 04:58 PM
JamesC's Avatar
Re: posi???
Most everything you'll need to know is listed in the link I provide above.
JamesC
Old Jul 19, 2009 | 07:11 PM
Daniel Doerksen's Avatar
Car: 1986 T/a
Engine: 5litre TPI
Transmission: T-5 5speed
Axle/Gears: 3.42 1999sscamaro torsen lsd
Re: posi???
why not find gravel, stop break the tires loose move forward, stop. get out of car look to see if its its one tire fire or not. much easyier and fun
Old Jul 19, 2009 | 08:43 PM
89RS_82Z's Avatar
Re: posi???
i could catch both wheels in grass and gravel with my open, best way is yo do a killer burn out on pavment, if you leave 2 than heck yea
KO1
16
Oct 15, 2015 05:00 PM
92projectcamaro
Sep 29, 2015 07:07 PM
