1LE vs JG1 same or no
Old Nov 24, 2001 | 09:32 PM
joes88gta's Avatar
i was just checking my RPO codes and it seems i have JG1 which it says is an aluminum drive shaft is this the same as the 1LE or no.
Old Nov 25, 2001 | 07:09 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Yes.
JamesC
Old Nov 25, 2001 | 09:26 AM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
<font face="Verdana, Arial" size="2">Originally posted by joes88gta:
i was just checking my RPO codes and it seems i have JG1 which it says is an aluminum drive shaft is this the same as the 1LE or no.</font>
partly. 1le also has larger brakes. it is an indicator that you have a 1le car.
Old Nov 25, 2001 | 09:30 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
JG1 was included in the 1LE package. 1LE cars have the JG1 driveshaft, but JG1 cars don't nessacarily have the 1LE package.
If you live in Southeastern US, check us out!
South East Thirdgen
1987 Trans Am 305
14.88 @ 92.81
Old Nov 25, 2001 | 10:48 AM
joes88gta's Avatar
thanks for the reply. i was under the asumption that only the camaro had the 1LE option with an aluminum drive shaft. i didnt know the had the driveshaft on other cars...thanks again
Old Nov 25, 2001 | 03:48 PM
JamesC's Avatar
Apparently, I misunderstood your question. The JG1 is the RPO for what is typically called the 1LE alum drive shaft.
JamesC
Old Nov 25, 2001 | 04:58 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Technically, the shaft RPO is JG1, but since JG1 is included in 1LE "Performance Package", it is often dubbed the "1LE shaft". But to clarify, you can get the JG1 Aluminum Shaft w/o having 1LE.
South East Thirdgen
1987 Trans Am 305
14.88 @ 92.81
Old Nov 25, 2001 | 06:25 PM
JamesC's Avatar
GMTech is correct. I've sold more than 60 of these shafts on this site and CamaroZ28.com, and I would imagine not a single one is from a true 1LE car.
JamesC
[This message has been edited by JamesC (edited November 25, 2001).]
Old Nov 26, 2001 | 01:21 PM
Little GTA's Avatar
My L98 car has the JG1 driveshaft, however the 5 speed cars don't come with this. Can the 1LE driveshaft fit with the T5 manual transmission?
89 TransAmGTA L98/Auto Grey/Grey T-Tops
Best 1/8th: 9.02 @ 76
89 TransAmGTA LB9/5speed FlameRed/GreyLeather Hard Top
Old Nov 26, 2001 | 01:33 PM
JamesC's Avatar
Yes, the so-called 1LE alum shaft will fit a T-5 (and T-56 for that matter as well as several other trannies). I have one in my 5-speed 85 IROC, though I did have to swap the rear U-joint to another size.
JamesC
PurelyPMD
May 5, 2016 04:57 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
mcgarnicle
Sep 24, 2015 07:18 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
