How much whining is normal with Richmonds?
Old Nov 18, 2001 | 09:46 PM
IROC315's Avatar
Car: 01 Z28 and 89 Iroc
Engine: ls1 fti 3600,S60 w/3:73 gears
Transmission: A4
Axle/Gears: 3:23
I bought a complete rear with Richmond 4:10s already installed. The guy said he had a shop install them. I am no fan of Richmond gears since I had a set fail on me recently. I am going to give these a chance but they do have some whining after letting off the gas. It's not bad but a litte louder than the ones I had in it before. I didn't notice any wear on them. I have not added the GM limited slip addictive yet but plan to do so.
Old Nov 27, 2001 | 11:39 PM
IROC315's Avatar
Transmission: A4
Axle/Gears: 3:23
btt
Old Nov 28, 2001 | 05:57 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Mine are noticeable, but my stereo on low volume easily drowns out the noise.
ORIGINAL OWNER
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Partial TBI mods, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Richmond 3:42 gears, Torsen HD Posi
Sights & Sounds:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers. Spectre valve covers and accessories, Z28 grille w/aftermarket lights, MacEwen whiteface gauges
NEXT UP: the rest of the TBI mods & Suspension upgrades
Old Nov 28, 2001 | 09:22 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
They shouldn't wine at all, when installed properly, mine don't at all. But I have heard many people say they wine a little.
2 Tickets to game= $250
Gas= $20
Sitting 20ft. from MJ= Priceless
'86 IROC T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK HEADERS Hooker CatBack
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Nov 28, 2001 | 09:35 AM
Ed1LE's Avatar
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
Whining isn't the fault of gears, it's mis aligned gears from improper installation. Depending on how loud it is, it might not be that big of a deal but they should be pretty much completely quite. I just had a new set of Richmond 3.73's installed & the rear doesn't make a sound. I had a buddy's brother install a set in my 70 Chevelle when I was like 17 or 18 and they whined a good bit, but lasted several years...& I was pretty hard on 'em too!
As for Richmond gears, as far as I know they're the largest & most reputable gear manufacturer so it must say something for their product.
'91 Z28 1LE; 355, Sportsman II heads, Edelbrock TPI w/ 58mm TB, Tremec TKO 5-speed, 3.73's & much, much more
[This message has been edited by Ed1LE (edited November 28, 2001).]
Old Nov 28, 2001 | 01:28 PM
92RSFivePointSlow's Avatar
Car: 2002 Harley Nightrain
Engine: twin cam 88ci
Transmission: manual
The whining might be due to a solid bearing spacer that the previous owner put in. The Pinion gear uses a crush coller that people replace with a stronger spacer, but since it's more rigid then the coller, it tends to make a little more noise. - Randy
Old Dec 1, 2001 | 02:24 PM
IROC315's Avatar
Transmission: A4
Axle/Gears: 3:23
I sure hope they hold up. The whole rear came off a low 12 second ride so I was fearing they were worn. After looking at them, they look to be in good shape. No visible wear.
Old Dec 2, 2001 | 04:06 PM
bottlefed89's Avatar
add the GM posi lube that will help if it dont spend a few bucks to have someone go through your rear to check it out its better to spend a few bucks to find out then spend $$$$ replacing the whole thing
Fanatic1074
Oct 3, 2022 05:57 AM
Linson
Oct 1, 2015 09:50 PM
Giocio
Oct 1, 2015 12:20 PM
thejimsterz28
Sep 30, 2015 08:52 PM
dusterbd
Sep 29, 2015 08:40 AM
