TH200C to TH700R4 Swap
Old Sep 13, 2009 | 02:16 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
what is needed to do this, new drive shaft cross member or what???
Old Sep 14, 2009 | 09:47 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: TH200C to TH700R4 Swap
If you had the 200 and want the 700, you'll need to swap driveshafts at the same time.
Old Sep 14, 2009 | 01:30 PM
89RS_82Z's Avatar
will the 200 cross members work with the 700r4
what about the lock up control
Old Sep 15, 2009 | 09:06 PM
89RS_82Z's Avatar
Bump
Old Sep 22, 2009 | 09:46 PM
89RS_82Z's Avatar
ok i know i need a new drive shaft
what about crossmember, tq arm, lock up wires,
i got the TV cable for a 700
Old Sep 22, 2009 | 10:40 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
The crossmember is different. The rear mounts on the body of the car become the front. If you're short on money, you can cut the tq arm a little short. I would rather get some aftermarket setup, such as a spohn trans crossmember with tq arm mount and tq arm. The driveshaft is shorter, could get one from another car or shorten what you have. May be able to keep the same lockup stuff, but I'd count on having to do something like your own switch for it or some other aftermarket control. TV cable is longer. Dipstick tube I believe is needed. Tq converter cover is different if you end up using one. Need a different shifter if you plan on holding it in 1st gear.
Old Sep 22, 2009 | 10:43 PM
89RS_82Z's Avatar
ok yea i figure the shifter, getting a new dip stick and conveter cover should come with the trans
Old Sep 22, 2009 | 10:45 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Never mind.
Old Sep 22, 2009 | 10:46 PM
89RS_82Z's Avatar
82 Z28
my 89rs is allready mostly rebuilt, especialy the trans and rear end
Cleotiz
Jan 6, 2018 08:56 PM
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
