best street performance 700r4 pan?
Old Sep 15, 2009 | 01:39 AM
tomclayborn's Avatar
Car: 88 iroc vert undergoing resto
Engine: 5.0 tpi
Transmission: beefy 700r4 rdeglcltch vetserv t/go
Axle/Gears: g92 b/w
ok so when i got my trans builtt my guy told me what to get red eagle performance clutches and bands tgo shift kit hardened sun shell vet servos and a stock vette converter for that year which is 88 external cooler i got the bm supercooler not the jumongous one and a pan with added capacity so here it is for the pan i got a derale that holds like 2 guarts extra and it had these tubes going through it for cooling it was really cool so neway within the first 2000 miles i bottomed out and tore it it hangs down a bit more than stock so i just put my factory pan back on 1. Will i be ok with the factory pan? all of the factory size pans i have seen only have small ribs on them at the bottom and i don't think it's worth it is it? 2. what kind of pans is everyone using that don't sacrifice ground clearance? not really fond of chancing a long trip loosing fluid the whole way and not knowing it thanks, any input is appreciated.
Old Sep 15, 2009 | 08:53 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: best street performance 700r4 pan?
I love the dreale pan on all 3 of my pickup trucks, but on both of my third gens, I'm happy to run the stock pans.
Old Sep 15, 2009 | 10:55 AM
Engine: 5.0 tpi
Axle/Gears: g92 b/w
i agree it is the best pan for a truck application or nething elso that is not as low as a third gen i think i'll be fine with the stock pan a trans temp gauge would let me know for sure i wonder if there is a pan with the hole set up to put in the sensor
Old Sep 23, 2009 | 02:25 AM
danziger's Avatar
Car: 1991 Formula Firebird
Engine: L98 with headers/exhaust
Axle/Gears: 3.23 10-bolt
I am also kicking around the idea of a deep-pan. Anybody else have some input?
Old Sep 23, 2009 | 07:35 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
You want problems, buy & install a deep tranny pan. Take a look at the bottom of the stock one and with the deep pan it only get worse. Be advised:
Old Sep 24, 2009 | 01:46 AM
danziger's Avatar
Thanks for the advice! That seems to be the consensus in my other thread.
Old Sep 24, 2009 | 02:40 AM
Engine: 5.0 tpi
Axle/Gears: g92 b/w
i'm keepin the stocker
Old Sep 27, 2009 | 04:43 AM
RPOL98's Avatar
Car: 90 IROC
Engine: 5.7L TPI
Axle/Gears: 9-bolt BW
I like the cast aluminum pans, with the theory that the cast pan helps provide structural strength to the trans case.
in your case, a stock-depth cast aluminum pan would be the way to go.
I've had a deep pan (cast alum) in my 90 IROC for over 10 yrs now (700R4), but I am indeed VERY careful with speed bumps. it is the lowest ground-clearance point of the car. it's been wacked a few times, but that's only dinged the "cooling" fins, it's a pretty hefty piece. maybe that's why they're there, as "skids".
anyways, so far so good.
Reddeath210
Oct 6, 2015 08:20 AM
someone972
Aug 30, 2015 12:52 AM
Thornburg
Aug 25, 2015 01:46 AM
Eric-86sc
Aug 24, 2015 09:01 PM
TreDeClaw
Aug 14, 2015 06:58 PM
