Currie rear end
Old Nov 3, 2009 | 11:19 AM
last_'s Avatar
Car: 91 Camaro RS
Axle/Gears: stock...
Currie rear end
Wanted to get opinions on this Currie rear end complete kit they spec'd me out with.
1 CE-2001L 9-PLUS HEAVY DUTY HOUSING - NOTCHED STYLE COVER $439.95 $439.95 1 CE-7008a 82-02 CAMARO BRACKETS WITH TORQUE ARM BRKT MOUNTED $349.95 $349.95 1 CE-0012 CURRIE PERFORMANCE AXLE PACKAGE $459.95 $459.95 1 CE-6014pb3x WILWOOD BRAKE KIT - REAR - W/INTERNAL PARKING BRAKE - BIG FORD NEW STYLE - 2.50 OFFSET - SRP ROTOR (.810 THICK) DRILLED/SLOTTED - BLACK CALIPER $824.95 $824.95 1 CE-6013w WILWOOD BRAKE LINE KIT - BRAIDED STAINLESS - 14 INCHES LONG WITH FITTINGS $69.95 $69.95 1 CE-6020w UNIVERSAL PARKING BRAKE CABLE KIT FOR WILWOOD BRAKES $119.95 $119.95 2 CE-6013-tab TAB - BRAKE LINE $0.95 $1.90 1 3M-9IN370S31TTSSN 9 Inch Ford (9IN) 3.70S Ratio - 31 Spline - TrueTrac (TT) Diff. - 9+ Nod Sportsman (S) Case - 9+ Sportsman (S) Pin Sup - 1330-L (N)ew Yoke $1,485.65 $1,485.65 1 CE-0118 LABSRVC - ASSEMBLE REAREND (INSTALL THIRD MEMBER AND AXLES) $99.95 $99.95 3 CE-9013 85-140W 9-PLUS (I QUART) - EACH $9.95 $29.85 FREIGHT:$0.00SALES TAX:$0.00COST OF PARTS:$3,782.10TOTAL:$3,882.05SURCHARGE:$0.00LESS DEPOSIT:$0.00COST OF LABOR:$99.95AMOUNT DUE:$3,882.05
Old Nov 3, 2009 | 11:59 AM
big gear head's Avatar
Re: Currie rear end
That's a lot of money. I think I sold a very similar Moser 9 inch for about $400 less than that.
Old Nov 3, 2009 | 12:10 PM
last_'s Avatar
Car: 91 Camaro RS
Re: Currie rear end
A lot of money? Yes indeed. Worth it? Who knows. Could expect years of fun driving with that though. And that is the point of my build.
And if you know of a similar rear end let me know. Has to put up with no more than 500 ft lb at the wheels. And no less than 430.
Old Nov 3, 2009 | 03:29 PM
EvilCartman's Avatar
Car: '82 Z28
Re: Currie rear end
The Currie housing is a nice part, didn't have any problems with mine. Got everything from them except the 3rd member which I bought local.
Old Nov 3, 2009 | 03:36 PM
Re: Currie rear end
Are they not charging you any shipping on this rear end?
Old Nov 3, 2009 | 04:30 PM
badgta's Avatar
Car: 1991 FORMULA
Engine: ZZ4 + LT4 HT CAM 430HP
Transmission: 700-R4 COMING T56
Axle/Gears: 9" 4.56's (COMING)
Re: Currie rear end
i have a moser 9", housing and axle package, stuffed with a detroit truetrac, yukon 4.56 gears, aluminum pinion support, daytona style 3.062 bearings, 31 spline axles, strange center section, and a 1350 billet yoke....
a got the ls1 rear brakes to go with it as well, ready to bolt in... only problem i found was with the torque arm bracket hit 1 centersection finn, a little grinding and i will be set, haven't even installed it yet..
to me, moser all the way
adam
Old Nov 3, 2009 | 04:33 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Re: Currie rear end
thats a bit Much..are you puting out more then 1000 HP??
i got a complete bolt in 9" from them with detrt locker 4.10 .31 spline axls
that red anodized front Hub thing.1/2 studs .and. made to put up with 1000HP beating on the weekends... $2200/$2300 to my drive way..SO MY 400 TO 600HP beatings are NOTHING!!to it
took mine out.. and slid the new one in.. like it had came from there!
my disk drakes fit like a glove!!! (1LE CAR)
just get the housing with the pinon support.. and what gears you like..
side note i dont USE the tork arm parts on my 92 Z28
it's all south side Lift Bars.and subframe..so i think it was $200 Less for mine..thats why it was 2200 to 2300 feels so much better. driving it with out that ARM...car stands up when you stand on it.. its just feels better!
Old Nov 4, 2009 | 09:12 PM
badgta's Avatar
Car: 1991 FORMULA
Re: Currie rear end
no, just gonna be a 350, afr 195's comp xfi 292 with a turbo is all, that or supercharger.... all 4340 bottom end and all after market, suspension drivetrain etc, only thing will be stock is the t56.....
will be launching through mt et streets....... maybe 2 times a year at the track if even that...
Old Nov 5, 2009 | 02:53 AM
Re: Currie rear end
Just have them do the housen with the Locker and the Gears you want.
set Up to bolt into your car.. with the Pinon support/Hub 1/2 screw in studs.31 spln axls. using your Disk drakes (you have them?) and total to you
should be less the $2500.
your not going to brake it..
forgive the dust..my car has been sitting for 7 years..just took this photo
Bolts right in less then $2300 to my drive way..takes about 45 min to install by your self..(then for me 3 hrs of welding) after selling pinon angl.
Old Nov 5, 2009 | 06:04 AM
86TA355SR's Avatar
Car: 88, 89 & 91 GTA
Engine: 355 Super Ram/350
Transmission: TH-375/700R4
Axle/Gears: Currie Ford 9"/3.70
Re: Currie rear end
I've had a Currie rear end in my Trans Am for over 10 years and never had a problem. It has survived a supercharger, a built 350, a manual valve body turbo 400 that shifts very hard and slicks at the track. I broke/rebuilt 2 other rearends and stepped up to the Currie piece. It's a good piece and worth the money in my opinion.
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
