Rebuilt 700R4 Shifting Bad and Wont Kickdown(PLEASE HELP)
Old Nov 11, 2009 | 04:51 PM
mavcar38's Avatar
Car: 89 Iroc
Engine: 350 Carb
Transmission: 700R
I have an 89 Iroc that I put a new crate carb 350 in and had the tranny rebuilt. I have an Holley 600 Carb and have the appropriate Brackets and linkage connector. I have adjusted and readjusted the tv cable several times. The car will shift fine through gears 1-4 on a light acceleration. On moderate accel it feels like it is sliding trough the gears. When I floor the car it will not kickdown, every now and then it seems like it wants to for a spit second. Its almost like my tv cable is too long....Could this be the case? I dont think its the tranny as it shift fine manually. Please help me out!!!
Old Nov 11, 2009 | 04:57 PM
cIaRmOaCrZo's Avatar
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
Re: Rebuilt 700R4 Shifting Bad and Wont Kickdown(PLEASE HELP)
yeah those are symptoms of mis adjusted tv cable (to far forward, not pulling on the hook far enough). and my car was a case of just adjusting the black plasic tube that the cable goes through, but on my buddys (which sounds like yours) had too long of a cabe, no matter how far back we adjusted it. to fix his to work, we just cut the tiny bulge on the end of the cable that hooks to throttle body lever, and then put a cable stop in place of it and just pulled all of the slack out and tightend downt the cable stop. works perfect now. hope that helps
Old Nov 11, 2009 | 05:18 PM
mavcar38's Avatar
Car: 89 Iroc
Engine: 350 Carb
Transmission: 700R
Once you guys pulled the slack out with the cable stop did you adjust the tv cable the way youre suppose to? How was the slider positioned when you took the slack out? Thanks....Im really frustrated....engine has barely 100 miles on it, runs great but I cant get the tranny right, Im afraid Im going to burn it up if I dont get it right soon.
Old Nov 11, 2009 | 05:48 PM
Engine: 383 hsr
yeah, we pulled the black slider out almost as far as it can go, then pulled the slack out of the cable, then tightened down the cable stop. then made adjustments from there. and yeah you deffinatly do NOT wanna keep driving it under-adjusted like that. itll be toast
Old Nov 11, 2009 | 05:55 PM
mavcar38's Avatar
Car: 89 Iroc
Engine: 350 Carb
Transmission: 700R
Do you have a picture of the cable stop or your setup. Ive looked on summit and jegs and cant find anything. Thanks again for the insight....Im praying it is just he tv cable causing this.
Old Nov 11, 2009 | 05:58 PM
Engine: 383 hsr
im at school, and remember its on my buddys car. so i couldnt get pics. but its really simple. we baught this cable stop at a local go kart store/shop. they were only a dollar. but im sure almost anywhere would have them. maby even home depot lol.
Old Nov 11, 2009 | 06:01 PM
Engine: 383 hsr
oh and when you said youv adjusted it and what not, did you adjust it as far back into the bore as you could??
Old Nov 11, 2009 | 06:20 PM
mavcar38's Avatar
Car: 89 Iroc
Engine: 350 Carb
Transmission: 700R
Duh me....forgot it was your buddies car. Sorry. I pushed it back pretty far...do you want it to go all the way back inside so you cant see it? Im going to try to mess with it friday or sat....we are having a noreaster now and I cant mess with it.
Old Nov 11, 2009 | 06:24 PM
Engine: 383 hsr
if its so far back to where you cant see it, it might not hold in place (might even fall out the back). but id at least put it on the last click or two and see if it MIGHT be enough. if not, then yeah try the cable stop. and whats a noreaster??
Old Nov 11, 2009 | 06:33 PM
mavcar38's Avatar
Car: 89 Iroc
Engine: 350 Carb
Transmission: 700R
Noreaster is a big *** storm....kind of like a tropical storm, just a little weaker. I saw the transfixleo method on here too. Im going to try that as well.
Old Nov 11, 2009 | 06:35 PM
mavcar38's Avatar
Car: 89 Iroc
Engine: 350 Carb
Transmission: 700R
Oh yeah, at one point I had the slider so far back it would come forward by the clicks...it just all shot forward at one time. How did you connect the cable if you cut the black connector off?
Old Nov 11, 2009 | 07:01 PM
Engine: 383 hsr
hmm, thats wierd that the cable shot forward by "ratcheting", another person on here said they had that same problem too.
and this is what we did, we cut the very tip of the cable off with snips.(that little casting bulge that acts like a cable stop) and after we cut that off, we put the black oval shape piece that connects to the throttle linkage back on the cable, then put the cable stop on after that. the cable stop was used ONLY to keep that black piece on and to get rid of slack.
Old Nov 11, 2009 | 07:59 PM
mavcar38's Avatar
Car: 89 Iroc
Engine: 350 Carb
Transmission: 700R
Ohhh, gotcha....When the weather clears Im going to try a couple more things....if it doesnt work then I will cut it and use your method...I hope it works!!! Do you remember how tight the cable was? I know on my TPI it wasnt that tight.
italiano67
Dec 11, 2016 09:21 AM
Reddeath210
Oct 6, 2015 08:20 AM
g.l.mos
Aug 22, 2015 12:02 AM
crazynights
Aug 21, 2015 06:53 AM
TreDeClaw
Aug 14, 2015 06:58 PM
