TCC lockup toggle switch: pro’s and con’s & proper operation
Old Jan 5, 2010 | 04:02 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Did search, found the article, but to many opinions spread out all over the place.
https://www.thirdgen.org/torqueswitch
Can we narrow it down.
What are the pro's and con's of having it on a switch?
What is the proper operation or use of said swtich for the novis?
[since it is the cheap way out when you lose the computer]
Street use
When to turn it on, what speed, rpm....
When not to turn it on.
Racing
Old Jan 5, 2010 | 04:52 PM
RU1NER's Avatar
Re: TCC lockup toggle switch: pro’s and con’s & proper operation
For racing you would leave it on the whole time right? 1st won't lock anyways.
Old Jan 5, 2010 | 06:09 PM
TheBigJ's Avatar
Car: 85 Firebird
Engine: SBC 383/88BW
Transmission: Built 700R4
Axle/Gears: Moser 9in/3.55
I don't run it locked up racing, afraid the lockup won't take the power, I don't even run into 4th gear during racing (slow fluid movement, and hot = bad)
I run it on the street locked up only when i'm in 4th gear, BUT i don't let it hit 4th unless I am at least running within my powerband so it doesn't bog
Old Jan 5, 2010 | 11:30 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The TCC clutch is a weenie little thing that was intended to be unlocked under just about any acceleration at all. I wouldn't lock it up at WOT.
Old Jan 5, 2010 | 11:51 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I run mine solely from a toggle - I had a vacuum switch installed, but wasn't happy with the timing of the lock and unlock, so I disabled it and I run solely on a toggle. I lock it when I get above 50mph and then only when I'm going to be on a decent cruise (aka highway with no upcoming red lights). I unlock whenever I start slowing for the upcoming stop - like right when I fall below 40 mph. Hope that helps.
Old Jan 6, 2010 | 06:58 AM
RU1NER's Avatar
I figured you left it on for racing cause it was suposed to shave almost .2 seconds off the quarter?
Old Jan 6, 2010 | 07:26 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
what about the B&M kit that is adjustable?
Old Jan 6, 2010 | 10:13 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
https://www.thirdgen.org/forums/carb...c-control.html
Old Jan 6, 2010 | 12:35 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Hey, well who decided to hide that in the carb section???
I only searched the trans section.
Old Feb 4, 2010 | 11:40 AM
3rdgenmaro's Avatar
Car: 88 IROC
Does anyone know of a place other then GM Parts direct to get the vacuum switch? I keep putting in the number into their search and it keeps coming back as unavailable.
Old Feb 4, 2010 | 11:46 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Try one of the alternate vacuum switches listed.
Fanatic1074
Oct 3, 2022 05:57 AM
tmellott89
Oct 14, 2015 02:06 PM
djmarch
Oct 2, 2015 10:41 PM
FormulaEngland
Sep 30, 2015 01:50 PM
dusterbd
Sep 29, 2015 08:40 AM
