car spins tire when backing up....
Car: 1985 pontiac transam WS6
Transmission: t-5 5 speed manual
i don't know if this is the right board or not.....but i am having some troubles with my 1985 T/A. the problem is that when you shift into reverse, it will act like the brakes are locked and spins the passenger tire....it has a T5 manual and a 3.73 gears with disc brakes......any help will be greatly apprecated
Car: 87 GTA
Re: car spins tire when backing up....
Hint.....Less pressure on the pedal, from the right foot!
Otherwise, your car should drive, not spin a tire. (unless your on ice)
Otherwise, your car should drive, not spin a tire. (unless your on ice) Joined: Aug 2006
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
could be a combination of that and the passenger side rear brake caliper not working
bad thing about it....when it finally pulls back.....its sounds like it is draging the front tires.....
Car: 86 Trans Am
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Would a low reservoir cause similar situation? Air in the lines//master cylinder?
Car: 82,83,99 T/As
Engine: 350,350,383
Transmission: ST-10,700r4,4l60e
Axle/Gears: P-3.23,P-3.42?,P-4.10
check the calipers and make sure theyre not locked upfront. check all the pads. make sure the rear calipers are working. check brake fluid level and color. bleed brakes if anything.
is it the stock rear? did it always have discs? if not, you could have the wrong proportioning valve.
there could be many things that could go wrong, need more details.
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
I agree,sounds like you might have a locked up brake. Might need, like said above, plus maybe need hoses. they sometimes break apart internally and you can't see it.
jack up your car, all four tires off ground, and leave in neutral, spin by hand....they should spin easy. If they all do, go push down on brake and then get out and quickly re-check them. Might only be sticking for a little bit.
found out that the drivers side brake would lock up and very slowly bleeds off....ty for the help everyone
1992rs/ss
Jan 31, 2025 05:10 PM
