3.42 posi out of a 97 Firebird, need some help.
Old Mar 28, 2010 | 09:29 PM
mikeirocz1's Avatar
Car: 91 RS and 88 IROC-Z
Engine: 305 TBI and 383 Carb
Transmission: 700R4/2200 stall & 700R4/3500 stall
Axle/Gears: 3.42 posi and 4.11 posi
I picked up a 3.42 posi rearend with disc brakes from a 97 firebird to put in my 91 RS. Does anyone recommend a porportioning valve to use? It has drum brakes on the stock rear. Can I use my stock e-brake cables or do I need to use some from a 97 firebird? Also, the rear had the traction control on it. It has an electrical connector on top of the housing, do I need to do anything with that or leave it alone?? Thanks for any help and information!
Old Mar 29, 2010 | 07:14 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 3.42 posi out of a 97 Firebird, need some help.
1LE combination valve, 2nd design. 89-92 parking brake cables, 1st design if you have a tunnel-mounted adjustment mechanism, the 2nd design if you don't. (You might try the 97 cables). More info toward the bottom of the following link:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Mar 29, 2010 | 09:16 AM
mikeirocz1's Avatar
So I will need to get the 90-92 1LE proportioning valve that Ed sell's and ebrake cables for a 92 Z28 with disc rear brakes?
Old Mar 29, 2010 | 12:28 PM
mikeirocz1's Avatar
Will I need to switch out the speedo gears in the tranny to make the speedo accurate?
Old Mar 29, 2010 | 12:53 PM
JamesC's Avatar
Yes. Yes (no tunnel mount). And yes to the speedo gears if the rear isn't the same ratio as the original.
JamesC
Old Mar 29, 2010 | 01:27 PM
mikeirocz1's Avatar
How do I figure out which speedo gear's to put in the tranny?
Old Mar 29, 2010 | 02:41 PM
JamesC's Avatar
I could help with the T-5, but I'm unfamiliar with the drive and driven gears for the auto. If you're going from 2.73's to 3.42's, I assume you need to swap both out. I suggest calling the following site--I think they'll be able to provide all that you need:
http://www.transmissioncenter.net/sp...n_______va.htm
JamesC
Old Mar 29, 2010 | 09:18 PM
mikeirocz1's Avatar
yeah, my stock rear was a 2.73. I will check out the link, thanks. I picked up the ebrake cables today and going to order the proportioning valve now.
Old Mar 31, 2010 | 01:26 PM
mikeirocz1's Avatar
Does anyone know the measurements from axle flange to axle flange on the 93-97 and 98-02 rearends compared to third gens?
Old Apr 2, 2010 | 11:00 AM
mikeirocz1's Avatar
is the 93-97 rear longer than the 98-02? If so, how much?
Old Apr 2, 2010 | 11:04 AM
JamesC's Avatar
The link in post #2 has some info on fourthgen rears, to include length.
JamesC
Old Apr 4, 2010 | 09:31 PM
mikeirocz1's Avatar
ok, thanks
Warlocksirix
Sep 3, 2015 12:26 PM
Djmathis123
Wheels and Tires
Aug 23, 2015 11:34 AM
Dialed_In
Aug 20, 2015 01:45 PM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
