Stripped my 10 bolt filler plug
Old Apr 11, 2010 | 08:35 PM
Grumbles's Avatar
Car: 1978 Chevrolet impala
Engine: 350ci 300hp/356tq pace crate
Axle/Gears: 3.42 Yukon posi
Thing was in there solid, 3/8ths socket ended up stripping it pretty good. What do I do now?
Old Apr 11, 2010 | 08:51 PM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Re: Stripped my 10 bolt filler plug
Hello Grumbles!!!
Get the "large" screw extractor, and try that, use plenty of pentrating fluid, and maybe a "little" heat at first!!!
Do you figure that someone used "Red" Loctite?????
No screw extractor..........drill it out.........re-tap/heli-coil it......replace with new plug!!!
Old Apr 11, 2010 | 09:07 PM
Grumbles's Avatar
Can't tell if it's got loctite on it, way too grungy to see.
Could I just tap/braze a nut on the diff cover and use that instead? seems more convenient.
Old Apr 11, 2010 | 09:09 PM
regal301's Avatar
Car: 1988 iroc-z
Engine: 350 Vortec TPI
Axle/Gears: 3.73 4th gen Torsen 10bolt
get a small screw driver dig and pick all the dirt out of the square drive hole,get a good ball peen hammer and hit the face of the plug squarely 4-5 times,then use a air impact gun or a hand impact driver to get it loose.
those plugs are fairly deep and dont fully strip out that easy.
dont keep pulling away on it with a regular 3/8 drive ratchet or it will strip. get,find or borrow an impact and it will come out.
if that dosent work,a skilled person with a air chisel can drive it loose.
dont drill until you try those methods.
Old Apr 11, 2010 | 09:12 PM
regal301's Avatar
Car: 1988 iroc-z
a 1/2 drive gun with a 1/2 to 3/8 adapter gets them out every time.
its a pipe thread so its tapered and some people like to tighten the **** out of them for no reason.
Old Apr 11, 2010 | 09:24 PM
big gear head's Avatar
Stick a bolt in the hole and weld it. This will put enough heat into the plug to loosen it some and the bolt gives you something to put a wrench on.
Old Apr 11, 2010 | 09:59 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Welding a bolt in the plug is the best way to remove stripped stuff like that. You just need enough weld around the plug to hold the bolt as it turns out the plug.
The plug doesn't need to be super tight when you install it. Some thread sealer or pipe dope and just snug it up. It's not like there's any pressure behind the plug and the oil level is below the plug.
A new plug will just be a 3/8" pipe plug.
Old Apr 12, 2010 | 12:48 AM
Grumbles's Avatar
sooo.... is my idea of just tapping/brazing a nut onto the diff cover a bad one?
Old Apr 12, 2010 | 12:56 AM
Hello Grumbles!!
Yup!! Bad idea!!
I guess my "drill it out" wasn't well received either!!!
The "weld a nut" idea is good, so is the "impact gun" one, give them both a try, impact gun first!!
Old Apr 12, 2010 | 07:08 AM
regal301's Avatar
Car: 1988 iroc-z
now if everyone had a mig/arc welder and could weld that would be a great idea.
Old Apr 12, 2010 | 09:15 AM
Grumbles's Avatar
Agreed.
The sad part is I just traded my mig welder for an L31 not even two weeks ago.
Old Apr 12, 2010 | 09:40 AM
Grumbles's Avatar
Impacting it out was a fantastic idea and worked like a charm despite it being nearly circular inside. Thanks a bunch Regal301
Old Apr 12, 2010 | 10:42 AM
regal301's Avatar
Car: 1988 iroc-z
your welcome,no problem,and good luck in the future
its amazing what an impact will bite on to compared to hand tools.
Old Apr 12, 2010 | 08:52 PM
AlkyIROC's Avatar
Car: 87 IROC L98
It's amazing what and impact can also easily strip.
Old Apr 12, 2010 | 09:15 PM
regal301's Avatar
Car: 1988 iroc-z
dont blame the tool, blame the operator.
Old Apr 12, 2010 | 11:54 PM
Hello All!!
So..........is the impact gun like a large screw extractor, in some sort of convoluted way?????
Glad that it worked for you Grumbles!!
Glowsock
Jul 24, 2025 03:15 PM
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Feb 28, 2016 03:33 PM
1nastygta
Aug 8, 2015 07:38 PM
