T5 Clutch engagement issues
Old Apr 11, 2010 | 12:54 AM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Ive searched for this for a while, and cant find this problem.
When I press my clutch pedal in, I have to be very fast with my shifting, as the clutch will release itself slowly, until the gear is engaged and the car moves itself, or making the shifter very hard to put into neutral (because its actually IN gear still).
I crawled under the car and had a friend press the clutch, and hold it, and I can physically see the slave cylinder (new) slowly letting itself back in, as if he was taking his foot slowly off of the pedal.
This problem makes this car hard to drive, not to mention very unsafe, if it happens at the wrong time.
I also notice that if I apply light pressure to the pedal and slowly push it in with little to no force, it will just keep going to the floor, and not release the clutch.
Could it be the clutch master cylinder? Thats my only clue, but I am not sure.
Thanks!
Old Apr 11, 2010 | 08:08 PM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Re: T5 Clutch engagement issues
Thanks!
Hello bradley23150!!
It sounds like you have an internal leak, (no fluid leaking outside of the slave, or the master cylinder)????
You of course have checked to see that the fluid in the master cylinder is at the proper level, and is not just pumping air????
Old Apr 11, 2010 | 09:48 PM
Yes, Its full, and I bled the new slave cylinder. I noticed a SMALL amount of fluid on the master when I looked under the dash, but not much.
Old Apr 12, 2010 | 01:21 AM
Well if it's full, and you bled the system properly, then that leaves an internal leak at the master as your problem!!
Try bleeding the system again, following the service manual procedure, and see what you get!!
The master cylinder for the clutch is not under the dash, it's up underneath the brake booster, under the hood!!
Old Apr 12, 2010 | 01:24 AM
I noticed in your info on the left hand side that you quote a 3.23 BW 9 bolt!!
How did you get a gear set that BW didn't make for the 9 bolt???
Car: 1988 IROC vert
Engine: 357 Vortec
Transmission: WC T5
Axle/Gears: 3.23 BW 9bolt Disc Brakes
3.45 or 3.27 I can believe, but not 3.23!!
Old Apr 12, 2010 | 01:46 AM
Actually the master is half in/out through the firewall, the part I saw with a bit of fluid on it was inside.
Thats what I was told when I bought the rear, most likely 3.27 than.
Old Apr 13, 2010 | 12:07 AM
The part of the master that's half in/out is just the actuating rod, as the master cylinder is actually outside against the firewall, the reservoir is up top outside by the brake booster, and you know where the slave cylinder is!!
If your seeing a small amount of fluid inside, on the actuating rod, it's most likely that your master cylinder is shot, causing your problem!!
Is the rear end not original to the car??
Old Apr 13, 2010 | 02:23 AM
No, the rear is from, I believe, an 87 IROC. I've modded this car pretty far from stock.
Know where to get a master for cheap?
It WAS:
305 TBI (L03)
3.08 drum non-posi
Old Apr 13, 2010 | 02:38 AM
It WAS:
305 TBI (L03)
3.08 drum non-posi
Try your local dealer for a price, part # 385387.......verify that part number when you get there, so that it's a good number for your car!!
My rear is not original to my car either, it was changed within the first year via some strange deal..........between two dealerships!!
My car was 3.45 BW 9 bolt Posi, but someone got a bright idea of changing it for a junkyard special 3.27 BW 9 bolt Posi!!!
777Shock777
Oct 29, 2015 04:30 PM
Papaginos
Sep 27, 2015 03:29 PM
theshackle
Aug 31, 2015 10:47 AM
87 camaro iroc
Aug 20, 2015 07:47 AM
redmaroz
Aug 16, 2015 11:40 PM
