Shifter for TKO 600
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Shifter for TKO 600
I am planning on swapping in a tko 600 into my car soon and had some questions about what to use for a shifter. From what I know, the tko comes with a hurst shifter on it when you buy it. So, would all I need to do is buy a aftermarket shifter handle and that would be it? (Plus modify it with a drilled plate to move it back far enough). What shifter handle could I purchase that would make the shifter resemble the stock shifter? I would like it to remain at the stock shifter heigth. Any shifters you would recomend?
Re: Shifter for TKO 600
Might be an issue of personal preferance. I used to use a TKO, in my old F body, not the 600 though. My car was a FB as compared to your Camaro. I found out on my trans anyway, that a longer stock length, like the one they supplied, was not ideal. And the one supplied was just horrible, as far as shifting, and fit with a stock console goes. After playing around with a few shifters, I settled on a Pro 5 0 shifter. That was basically a short throw shifter. Cleared the console, and nice shifting. HTH.
Car: 85 Iroc-Z
Im not a fan of the short throw shifters and would prefer not to have one. Does anybody know the length of the stock shifter?
Car: 86 Trans Am
Engine: 408 stroker sbc
the stock shifter is a "short throw" shifter.
the steeda tri-ax shifter works too, just have to lengthen the handle that comes with it a little. the setback of the handle is perfect though
Car: 86 Trans Am
to use the supplied hurst shifter, the handles needs to be setback 2", you can do this with a steel/aluminum plate to bolt everything together, or fortes can make an offset shifter.
I have the offset shifter, and i use a hurst c3? shifter stick, the height is close to stock. That particular stick is rather expensive for some reason though. Not using this setup anymore since i changed ot a tri-ax.
the stock hurst and the vette stick
hurst 538-7991 stick, i think
fortes offset shifter thingy
somebodys trans with a setback stick, dont know if it works or hits anything
Car: 87 iroc z
Engine: 5.0 TPI
Transmission: t5
Axle/Gears: stock
how is the stock shifter a short throw... i would love an actual short throw for my car but can never find one... had a short throw in one of my old cars and your barely had to flick your wrist to shift.....
Car: 86 Trans Am
Car: 87 iroc z
Engine: 5.0 TPI
Transmission: t5
Axle/Gears: stock
pls send me a link if you have one i cant find anything... especially local... cant even find a used 350 block .
Car: 86 Trans Am
Car: 87 iroc z
Engine: 5.0 TPI
Transmission: t5
Axle/Gears: stock
well this suxs... b&m doesnt have any in stock nor does hurst right on their website.... anyone got one they want to sell !!!
Car: 86 Trans Am
Car: 87 iroc z
Engine: 5.0 TPI
Transmission: t5
Axle/Gears: stock
well summit wont take my credit card cause its a prepaid and i dont have a regular one... dont really like spending money i dont have.. i would prefer ebay because they have paypal and my paypal just echecks out of my account..... since when did everything require a damn credit card got money in the bank i cant even spend so stupid
