Clunk when accelerating
Old Aug 4, 2010 | 12:53 AM
FireInMe17's Avatar
Car: 1990 Camaro RS
Engine: 355 Vortec TPI LT4 Hotcam
Transmission: TH700-R4
The car will always make a clunk noise when accelerating, it happens when the transmission shifts from 2 to 3.
Bad U-joints? Or something else with the transmission or the rest of the drivetrain/ differential?
Old Aug 4, 2010 | 09:45 AM
FireInMe17's Avatar
Car: 1990 Camaro RS
Re: Clunk when accelerating
bump
Old Aug 4, 2010 | 09:57 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Probably should check the transmission mount.
JamesC
Old Aug 4, 2010 | 12:24 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Could also be a motor mount.
Usually a U-Joint will 'clunk' when put into gear. But the mounts 'clunk' as you described on gear shifts. The 2-3 shift is usually the more 'violent' of the shifts - usually higher rpm's on that shift since the 1-2 shift usually happens too quickly (like in the middle of a normal turn) as opposed to the 2-3 shift that's usually always on a straight-away and us Camaro/Firebird folks like to really have our foot in it then
Old Aug 4, 2010 | 02:42 PM
FireInMe17's Avatar
Car: 1990 Camaro RS
I never thought about the motor mounts, I kinda had thoughts about the u-joints going bad because it does clunk when I put it in gear, put some times its not all that bad.
I guess it wouldn't hurt to get new mounts, the engine doesn't really move that much when I start it up or revv it with the hood open, but who knows.
As for the u-joints, they are still the original ones to the car so it wouldn't hurt to get new ones either.
Old Aug 4, 2010 | 03:03 PM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
tranny mt, replace w/urethane mt...
Old Aug 4, 2010 | 03:08 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
+1 to trans mount. If bad replace with a poly one and never worry about it again. Very common problem.
Old Aug 4, 2010 | 03:13 PM
marekdennhardt's Avatar
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
I say trans mount (crossmember)
Old Aug 4, 2010 | 07:12 PM
FireInMe17's Avatar
Car: 1990 Camaro RS
Already been replaced.
Brand new one on the car.
Less than a few months old. And I know I didn't bust it, it did it before and after the replacement.
Pac J
May 17, 2020 10:44 AM
db057
Jan 10, 2020 08:55 PM
RedLeader289
May 28, 2019 01:47 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
ULTM8Z
Sep 16, 2015 09:15 AM
