"t5" to 700r4 swap?
On Probation
Car: 1989 Formula,1991 z28
Engine: 400 Vortec Hsr,496bbc
Transmission: TKO600,TH400
Axle/Gears: 9"4.10, 9"3.73
"t5" to 700r4 swap?
my car is originally a 5spd..and im swapping to a built 700r4...
im finding conflicting info about this swap..
my main concerns are if my original crossmember, will bolt up to the T5, and what about the tq arm?
also, will my VSS plug, plug into the 700R4 vss?
and as far as the R4 lockup control goes, i plan on just using a kit
Car: 86 Trans Am
Engine: 408 stroker sbc
Re: "t5" to 700r4 swap?
crossmember is the same, torque arm should work, depending on the style of the mount on the trans. the mounts themselves will not interchange, but the direction of the "lips" on the torque arm vary, some face the driveside, other the passengerside. Its a matter of using the right bushing.
vss, i dont know if the plugs are the same.
On Probation
not to worried about the plug being the same, more or less concerned about the signal/compatability being the same..
if i need to change the pigtail, im ok with that..
ive read that the 86-89 cars all used 2kPPM signal, and that 90-92 used 4k ppm...
Car: 86 Trans Am
my 86 uses 4k ppm. pretty sure 3rd gens all use 4k.
whats the trans from?
On Probation
btw, you're car should have 2k ppm
The ECM for 90-92 TPI setups are designed to run on a 4000 pulse per mile vehicle speed sensor (VSS). On the other hand, the 85-89 TPI ECMs are expecting a 2000 pulse per mile signal. Many of the early TPI vehicles with a cable driven speedometer, had the VSS mounted behind the speedometer. The later MAF setups with an electric speedometer had a VSS buffer box mounted behind the dash. The VSS signal runs to the buffer, and the ECM grabs the VSS signal from the buffer box. The buffer box is also responsible for controlling cruise control and the speedometer. The later 90-92 models had the VSS mounted on the transmission, and ran directly to the the ECM. In this case, the ECM handles the signals which run to the speedometer, and cruise control.
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Pretty sure both my 88 firebird and 91 firebird Helms manuals show the VSS saying 4000ppm. I can break them out again and check, but I have only looked at the drawings for the V8 cars, I think the V6's were different
On Probation
everything ive found/read so far, is 2k for the 86-89s...and 4k for the 90+
apparently the 90-92 split the 4k signal in half, half went to the speedo, half went to the cruise control...
either way, hopefully the VSS signal is compatible...
Car: 86 Trans Am
my 86 was a lg4 carbed car, and yes it operates at 4k ppm
Car: 86 Trans Am
C409
Sep 1, 2015 03:42 PM
Eric-86sc
Aug 24, 2015 09:01 PM
