HOW TO PULL TRANSMISSION??
Old Sep 7, 2010 | 02:05 PM
I_R_O_C_Z_2_8's Avatar
Car: 1991 Trans Am GTA
Engine: 350 tpi
Ok guys so i've decided to make my life easier and pull my transmission out so i can drop it in attached to the motor...cause yesterday while attempting to put it in the motor hit the transmission and spilled tranny fluid all over my driveway i was super mad..So my question is how do i go about dropping the transmission is it just loosening the cross member and putting the transmission jack under it? thanks..im doing it on the floor on jack stands. so any help would be great thanks.
Old Sep 7, 2010 | 02:13 PM
Maeryk's Avatar
Car: 89 Formula 350
Engine: 355 long block TPI
Transmission: auto
Axle/Gears: Richmond 4:10 Eaton Posi
Re: HOW TO PULL TRANSMISSION??
you are gonna want a tranny jack, or at least a cradle for your floor jack. but I agree, it's easier to drop in the whole setup with a hoist than try to line up the bell housing with the tranny with the tranny already in the car.
Old Sep 7, 2010 | 02:22 PM
Engine: 350 tpi
yeah i got a transmission jack im going to borrow to do it...plus i think the gasket is bad cause as soon as the motor sat i little on the transmission and turned it sideways it started to leak all over..so i just gotta loosen the cross member and jack it down.
Old Sep 7, 2010 | 02:26 PM
Maeryk's Avatar
Car: 89 Formula 350
Transmission: auto
Every one I've ever had out has leaked at the tailpiece with the drive shaft out. Every one.
So, chock the tires good (if any are still on the ground) disconnect your shifter, speedo cable, etc etc. Loosen the crossmember mount bolt. Get the jack under it, take some weight off the crossmember mount, get the crossmember out of the way, drop the tranny, roll it out.
It's been a long time since I've dealt with a tranny, though.
Old Sep 7, 2010 | 04:38 PM
Engine: 350 tpi
yep i still gotta disconnect the lines too...but i think it spilled all the fluid out yesterday lol but we shall see how it goes this weekend.
Old Sep 7, 2010 | 04:40 PM
Maeryk's Avatar
Car: 89 Formula 350
Transmission: auto
you'd be amazed how much fluid they hold. Even more so if you were laying under the tranny which just dropped out of the car, mostly onto your chest, as the tailshaft slowly leaked it all into your hair, and it was running down under your back.
Old Sep 7, 2010 | 04:46 PM
KnightmareCS's Avatar
Car: 82,83,99 T/As
Engine: 350,350,383
Transmission: ST-10,700r4,4l60e
Axle/Gears: P-3.23,P-3.42?,P-4.10
What the other guys said.
Also, keep a drain pan under the tailpiece.
Just did a removal yesterday, took the engine/tranny out together and that thing was dripping the whole way.
Old Sep 7, 2010 | 05:05 PM
Engine: 350 tpi
lol well good thing i was not under the car when it was leaking or i would of been pretty mad...ok ill keep a drain pan under the tail shaft..does that part just slide out?
Old Sep 7, 2010 | 05:24 PM
Car: 82,83,99 T/As
Engine: 350,350,383
The tailshaft? If you have the driveshaft off and you unbolt it, it should.
If you're referring to the driveshaft, that slides right out.
Old Sep 7, 2010 | 05:42 PM
Engine: 350 tpi
my bad haha thats what i meant the driveshaft.
Old Sep 7, 2010 | 06:20 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
I pulled my 700 on Saturday and the trick to these is simply to unbolt the driveshaft from the rear end and drop it out of the rear; THEN - slide it back into the tail end of the tranny... this way you don't have a big nasty mess at the end. We pulled the trans and the ONLY drips we had were from the dipstick tube hole - It was the first time I'd left the driveshaft in and I'll never remove another trans w/o putting it back in before removing the trans from the car.
Some people have a driveshaft input yoke around just for this purpose, but honestly, the driveshaft worked just fine - a bit clunky to remove it all and get around the jackstands, but it did work.
Old Sep 9, 2010 | 02:34 PM
EFIhead's Avatar
since you have the trans out couldn't you lower the motor into the car and bolt it to the mounts, then reinstall the trans?
Old Sep 9, 2010 | 02:39 PM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
HUH?
Old Sep 9, 2010 | 03:19 PM
Engine: 350 tpi
exactly huh?? i have the motor out so im going to drop the transmission to put in together
Old Sep 9, 2010 | 04:34 PM
jakemussman's Avatar
Car: 1990 Camaro RS
Axle/Gears: 10 bolt, 3.73 Ratio, Torsen LSD
Could but he was saying It would be easier to take the trans out bolt it to the block and drop them in together instead of trying to line up the two and then bolt them up in the car.
Old Sep 9, 2010 | 07:12 PM
EFIhead's Avatar
nevermind
Vintageracer
Jan 10, 2020 05:33 PM
BlackphantomZ28
Apr 24, 2016 08:14 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
formula_novice
Aug 18, 2015 08:48 PM
mizz0313
Aug 12, 2015 06:45 AM
