Why has my transmisson bellhousing been cut?
Car: 1990 Iroc Z
Transmission: t56
Axle/Gears: 4:10
I just realized that my manual trans bell housing is cut at the bottom like where the dust cover goes on a automatic trans! why is that? shouldnt that expose my clutch? u can see my trans in the pictures on my reverse hood thread here https://www.thirdgen.org/forums/body...ml#post4675110
Car: `86 SS / `87 SS
Re: Why has my transmisson bellhousing been cut?
someone felt the need for an inspection window.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Or they didn't know to use the 153 tooth flywheel intead of the 168.
Engine: 383 Carb
Transmission: 4L60
The T5 needs the smaller flywheel to fit inside the bellhousing.
Car: 1990 Iroc Z
Transmission: t56
Axle/Gears: 4:10
its a 700r trans with a shift kit. i was thinking if something got in there it would be a big problem
Engine: 383 Carb
Transmission: 4L60
Car: 1990 Iroc Z
Transmission: t56
Axle/Gears: 4:10
the whole bottom half of the trans is cut off, looks like it was done with a jig saw cuz its not straight
Car: 1990 Iroc Z
Transmission: t56
Axle/Gears: 4:10
Here are more pics, and the car didnt have a shift boot so i was wondering if the shifter is suppose to look like this too?
That looks kind of long as far as shifter handles go, but is fine.
It's aftermarket so what it's "supposed to look like" is subjective.
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Damn I didn't notice the bellhousing lol that's crazy and if you had a center console in you wouldn't see that, the lower boot is to seal the opening from the trans that's all
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
i have removed/swapped a few T-5 transmissions . your bellhousing has been cut up . why , i have no idea ? would i get another bellhousing , yes . also get the front cover plate . i am very puzzled why someone would cut it up like that . good luck with your project .
Car: 1990 Iroc Z
Transmission: t56
Axle/Gears: 4:10
the shifter was long long even with the center consol in, i was wondering if my transmission has been modified since the shifter doesnt appear stock?
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Could be a cheap ebay shifter or one out another car, who knows I doubt anything is modified in it, unless its got stronger internals but idk
Car: 1990 Iroc Z
Transmission: t56
Axle/Gears: 4:10
doesn't feel cheap at all, very solid. anyway i could tell if it has been upgraded?
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
wow that much missing from the bellhousing has to weaken it surely, hmmmmm ...
hmm wow....
the f body T 5 housings are clocked 17 degrees...
most other models(if any others at all) are not clocked and instead are level across...
some trannys have the mount clocked this 17 degrees to, to be used with clocked housing..
so watch out when shopping for another one...
i have a v-8 third gen f body one sitting here, for sale or for trade, from a 92 v-8 t-5 f body.. and it is clocked,,
have fun!
hmm wow....
have fun!
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Welll if someone hacked the bellhousing I doubt it, only way to tell would be to open the case up, it doesn't look like its been cracked open
As lon g as you get a v8 bellhousing from a camaro or firebird you'll be fine
Car: 1990 Iroc Z
Transmission: t56
Axle/Gears: 4:10
no its an original 1990 iroc z with a manual transmission. i kno it came with a 305 but the previous owner had a high powered engine in it, he didnt go into detail on the size but it was nice, he kept it and gave me the rest of the car for $300. should i get a new bell housing or can i just make a fiberglass cover to cover the bottom up?
Car: 1990 Iroc Z
Transmission: t56
Axle/Gears: 4:10
Would it serve any purpose to get a new one though? Because I kno automatic trans are shaped like this and they have a shield to cover the torque converter and all the bolt holes are there so it should still be strong? What would the advantages of a new bellhousing be and what would be a disadvantage of just making a cover?
Car: 1990 Iroc Z
Transmission: t56
Axle/Gears: 4:10
another thing. i hear a t5 cant handle the torque of a 350, is that true?
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Car: 1990 Iroc Z
Transmission: t56
Axle/Gears: 4:10
Thanks that makes sence now. Maybe I need a whole new trans because I'm goin with a 350 and I was told they only put 305's on these cuz the 350 has too much torque. Would a 6 speed from a 4th gen be a good idea and what other transmissions would u suggest?
If you want to beat on the car, yes a T56 is a better trans. than a T5 by far.
I like the Richmond 6 speed I've driven.
Driving the T5 until it breaks wouldn't be a bad option.
Car: 1990 Iroc Z
Transmission: t56
Axle/Gears: 4:10
Yea I don't plan to be easy on my trans lol. But what car could I get a better trans from?
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Wow... anyway the 6 speed is an easy alternative since you're already running a t5, you've got your choice between ls and lt each has pros and cons, a search should give you a better idea or you can go aftermarket like richmond etc
Car: 1990 Iroc Z
Transmission: t56
Axle/Gears: 4:10
what would be the easiest choice, what manual trans can i put in that can handle decent power that would just bolt right in or would it be cheaper to convert to auto?
Car: 1990 Iroc Z
Transmission: t56
Axle/Gears: 4:10
well i removed the t5 today, took about 30 minutes, luckily it wasnt heavy and i just muscled it out. bout to try and sell it, goin get at t56
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
Yes, that'll happen unless you plug the hole by putting the driveshaft yoke back in.
Car: 1990 Firebird
Engine: 350 TBI
Axle/Gears: Auburn posi 3.73
Yes it is normal for the fluid to come out of the tail shaft when the drive shaft is removed. Next time you have to pull a trans you won't have such a mess to clean up.
Last edited by pound; Sep 28, 2010 at 02:12 PM. Reason: late to the party with "someone died under there"
Car: 1990 Iroc Z
Transmission: t56
Axle/Gears: 4:10
i just sprayed it off into the grass, no biggie lol. how much should i try to sell this for? i can get a t56 for $118 with warranty from my local auto yard.
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
If you can get a working t56 for 118 its either the steal of the century or there's some miscommunication in there.
Car: 1990 Iroc Z
Transmission: t56
Axle/Gears: 4:10
my auto yard doesnt sell by what kind of trans it is or what it came out of. they have a standard $88 fee for manual transmissions and $30 for a 30 day warranty if it dont work. you have to go in an get it out yourself.
Car: 1990 Iroc Z
Transmission: t56
Axle/Gears: 4:10
Well I went got the t56 yesterday. Found out I was wrong. It was $88 for the trans with only 30 days to return it, or $118 for 90 days to return it. I took 30 lol. After tax it was $97.76 for the trans. Car I pulled it from had 89,000 miles. You guys would love this place. All v8 motors are $218 complete with a $30 core charge. No matter what kind. 305, 350, 454, lsx, lt1, anything.
1985, 2004r, 700r, bellhousing, boot, cover, cut, cutting, dust, iroc, t5, th350, trans, transmission, transmisson
