One tire Fire
Old Oct 18, 2010 | 07:00 PM
Military Clone's Avatar
Car: 1984 Berlinetta
Axle/Gears: 3.08
One tire Fire
Hey guys I dont know really anything about rear ends. I know there are two type Posi and Diff. But what can I do to stop the one tire fire without going to a posi. Please help me.
Old Oct 18, 2010 | 07:55 PM
big gear head's Avatar
Re: One tire Fire
You can install a Lock Right in the differential that you have now. They are easy to install with normal hand tools.
Old Oct 18, 2010 | 07:56 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Re: One tire Fire
Depends on what type of differential you have, if you have an open or standard diff., that's just what it will do. If you have a posi or limited slip, you can rebuild or replace the posi.
Old Oct 18, 2010 | 08:38 PM
Re: One tire Fire
A Berlinetta would most probably have come with an open rear (without posi).
You could put a posi carrier in it, or a locker; or get a whole other rear.
Short of that, about all you can do to keep from the one-wheel-peel thing, is keep your foot out of it. Not sure what else you're looking for here?
Old Oct 19, 2010 | 02:57 PM
Axle/Gears: 3.08
Re: One tire Fire
Ok, but with is the different between an open and stanard rear end diff.
Old Oct 19, 2010 | 03:15 PM
GICATA's Avatar
Car: '83 WS6 T/A 65,000 miles
Engine: 5.0L vin H stock, 406SBC right now
Axle/Gears: Corp. 3.73
Re: One tire Fire
Nothing is different btw an open and a standard diff.
These are the two types:
1= open, standard, peg leg, one tire fryer...spins one tire usually the right one, or the one with the least traction.
2= posi, sure grip, locker.... has clutch packs or cones or ratchet locks, spins them both most of the time.
Old Oct 19, 2010 | 07:15 PM
Axle/Gears: 3.08
Re: One tire Fire
What do you all think i should do. Its a DD and somewhat going to be a weekend track warrior.
Old Oct 19, 2010 | 07:42 PM
red rock's Avatar
Car: 1987 iroc
Re: One tire Fire
I guess depending on finances, i would look for a posi rear end, new or used. But keep in mind if you change the gear ratio, you will have to also change your speedometer gear to maintain the correct speed.
Old Oct 19, 2010 | 08:02 PM
Re: One tire Fire
Chances are that if you find a used 3rd gen posi rear end it will be worn out and useless. These rear ends had the Auburn differential, which can not be rebuilt when they wear out. When a Auburn wears out you take it out and toss it in the scrap metal pile and buy a new one. Installing a new Eaton in your rear end would be a good idea, but you must have a 3.23 to 4.10 gear to use the Eaton. The Lock Right is the easiest to install and it will work in the differential that you already have. You just take out the 4 gears inside the differential and put in the Lock Right in their place.
Old Oct 19, 2010 | 08:52 PM
red rock's Avatar
Car: 1987 iroc
Re: One tire Fire
Probably the best advice you'll get.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
sahlomonic
Sep 20, 2015 07:15 PM
2MNYMaros
Sep 15, 2015 11:36 PM
dennisbernal91z
Wheels and Tires
Sep 12, 2015 12:28 AM
Ranbo108
Sep 9, 2015 12:20 PM
