700R4 Slow To Go Into Drive When Cold
Car: 88 IROC-Z T-Top car with Bose
Engine: L98 5.7
Axle/Gears: 9 Bolt with 3.27's
Hey guys,
Having an issue with my stock 88 IROC. When it's about 50 degrees or below, my trans takes a minute to go into gear after backing out of my driveway when switching from reverse to Drive or Overdrive. When its warm outside or I have driven it that day it seems fine. Any ideas on what could be causing the issue?
Car: 91' bird(WS6>>305TBI), 82'Regal
Re: 700R4 Slow To Go Into Drive When Cold
Your not alone... I gotta 91'Formula does the same thing. I changed the fluid and put in a new filter and the same issue persist only when she's cold. I just baby her, especially when she's cold cause I don't want to screw up the trani. I thought about adjusting the TV cable but if that was the issue it should happen all the time I would think. Anybody?????????
Engine: L98 5.7
I'm at 138k and climbing.....
125,000 miles and counting. The winter beast is back on the road and the Buick in the garage. HATE driving the Bird in the winter but have too much money and possibilities tied up for the Buick. I know>
Have to get too work somehow......
Have to get too work somehow...... Thread Starter
Engine: L98 5.7
[QUOTE=bitchin_buick;4727485]Bump.......
[/QUOTE
We will get an answer at some point......I'm sure someone has had this issue before.....
I checked the trans fluid on a level surface after it warmed up a bit. Was a half pint low, but I didn't drive it either, so I will check it after driving a little and post if there's any difference. Going to change the fluid in a few weeks too.
Nice Buick by the way.....love the wheels!
[/QUOTEWe will get an answer at some point......I'm sure someone has had this issue before.....
Everybody is scared of trani questions I suppose.... We get it, the trani doesn't shift properly ONLY when COLD into a SPECIFIC gear(not all of them). Is their a way to make this better before WE toast the Trani? In my case: New filter/fluid, Level checked properly, shifts fine warm. I'm 37 and don't BEAT ON MY BIRD like a young man. So what gives????????????
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
its hard to say over the board.. we need data, a trans gauge to see what your line pressure is... it can be worn seals that swell up enough when warm, worn or sticking valve body (even check ***** gummed up) vanes in the pump scorn or sticking its so many things idk.. try asking a trans guy because from what your asking I think you may want to ask a trans guy who knows from seen a "common" problem like this
Car: 1990 Camaro RS
Engine: 5.7 350
Transmission: Built 700R4 with 2700 stall
Axle/Gears: Moser axles with 4.10s POSI
So i have a 700r4 on my 90 and it does the same thing. But when i put it in 1st gear it goes right in...its really weird. Try that and let me know if it helps.
Engine: L98 5.7
I'm A noob......... Thread Starter
Engine: L98 5.7
The corvette servo fits in the side of the tranny and is supposed to improve the 2-3 shift.....most notably the lag time when under full throttle. Some vendors on here sell a kit or I think it can be bought from Summit for about $30.00. Well worth it in my opinion.
Engine: L98 5.7
Just a heads up on the lag time between the 2-3 shift.......I took the car to the track a few weeks ago and adjusted the TV cable to lower the shift point. As we all know these cars make no power at RPM. The car was shifting at 5500when the lag occurred. I brought it down to 4800 and full throttle upshifts were perfect. Car eventually went 14.45 @94. Had to readjust 3 clicks when done as it shifted two quick when not under full throttle. Took about a minute to do. Just thought I'd relay the info.
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
Just a thought, but i'll throw it out there anyway.
If its cold, I would think that the trans would have to warm up to reach the proper fluid viscosity before it will shift into OD.
I bought my 89 RS 2.8/700r4 with 180,000 miles on it and now I'm pushing 214,000 miles and the entire time it has done it. No rebuild on motor or trans. I do get on it at times, and I will occasionally run flat out on the highway at 3 in the morning. and other then the 2-3 shift, I've had no problems with it(as far as I know, the 2-3 issue is common without the corvette servo?)
Keep an eye on your temp gauge and see if it does it at a specific engine temp(to see if it is a consistent thing, just as a reference; unless the OP has a tran temp gauge).
I would think we need more input from other members to confirm if this happens to just about all of the 700r4(I guess without a rebuild, shift kit, servo, etc...). Does the OP have a stock 700r with nothing done to it?
Car: 1989 Formula -1986 T/A
Engine: 305 V8 FI- HO350 V8 carb
Transmission: 5 speed manual- Automatic
Axle/Gears: stock - unsure
