700R4 shifting question
Old Dec 11, 2010 | 06:19 PM
TX-SleeperC5's Avatar
Car: 1987 Trans Am GTA
Engine: 5.0 TPI
okay here's my question.
We have an 87 GTA with a 700R4 tranny. It has started acting up. I still shifts gears but only under hard acceleration. If you drive normally it stays stuck in gear.
Any ideas or suggestions ??
Old Dec 12, 2010 | 10:42 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Re: 700R4 shifting question
Check the tv cable for proper movement of the tv valve, and correct adjustment. If problem still exists, pop of the governor cover, and remove the governor for inspection.
Old Dec 12, 2010 | 01:02 PM
Engine: 5.0 TPI
tv cable ??
Old Dec 12, 2010 | 01:16 PM
wyochimneysweep's Avatar
Car: 92 chevy 1/2 4 wheel drive
Engine: 5.0L with TPI
theres a junior shift kit avaible to correct the sticking tv vavle in the valve body
Old Dec 12, 2010 | 02:01 PM
Engine: 5.0 TPI
So is that what the problem is.... a sticking valve in the valve body ??
Old Dec 12, 2010 | 02:32 PM
Its a known problem and if it doesnt have the update more then likely yes
Old Dec 12, 2010 | 05:45 PM
Engine: 5.0 TPI
So what you guys are telling me is that I NEED to install a shift kit, right...
Old Dec 12, 2010 | 08:34 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
tv cable ??
Yes. TV Cable.
It stands for throttle valve cable.
Your car has one, and it occasionally goes out of adjustment. Re-adjusting it as per the factory service manual my recommendation. This will cost you nothing, and may solve your problem.
As I mentioned earlier, the governor (responsible for shifting) may also be sticking, or have a stripped gear.
Resist the urge to throw shift kits and problem solver parts at a problem before checking it to be sure it is functioning as it should. If the root of your problem is in the trans, throwing parts at it usually costs money, and accomplishes nothing (or increases problems).
Old Dec 12, 2010 | 08:52 PM
hydrolic144's Avatar
Car: 1987 GTA Trans Am
Axle/Gears: Borg Warner 9-Bolt 3.27
Let us know what you find out
Old Dec 12, 2010 | 09:25 PM
sabbs5602's Avatar
i would like to know whats wrong with my transmission. i just bought a 1989 rs, and the guy who sold it to me said the trans is fine, but i need to let it warm up first for the trans to shift. and it sounds like the gears are slipping, anyways are these the symptoms of a transmission waiting to be replaced
Old Dec 12, 2010 | 11:02 PM
Engine: 5.0 TPI
Originally Posted by Floor guy
Yes. TV Cable.
I will try this tomorrow first to see where I stand.
Old Dec 13, 2010 | 07:25 PM
the junior shift kick i talk about is to fix a known problem in the earlier 700r4 that was later fixed. and all reman kits also come with this new throttle vavle for the vavle body. now i've never seen a tv cable come unadjusted by its self. its always by someone that doesnt know what they are doing. does your tranny shift at the same speed at half throttle as with full throttle? Try adjusting the tv cable but i think you may have to put the improved vavle in
Old Dec 14, 2010 | 07:12 AM
Engine: 5.0 TPI
I've NEVER adjusted the TV cable. The car just started doing the funky shifting thing all of a sudden...... I've only done 1/2 throttle. If I take off normally it stays stuck in 1st gear.
I had to work late yesterday so I didn't get a chance to try and re-adjust the TV cable. I really don't think i should even try it....
What happens if I re-adjust the cable and it gets worse ?!?!?! Then my son is left without a car !
Old Dec 14, 2010 | 01:46 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
My recommendation was to re-adjust as per the shop manual. If you do not know how to do this procedure, I would not attempt it (unless you are willing to learn it). There is only one correct setting. Failure to have it where it belongs will burn up your trans.
The adjustment procedure has been covered here, and other forums many times, so I am sure the search function will turn it up. It requires no tools, and takes more time to open the hood, than to adjust the cable.
Throwing parts (related to the tv system) will require adjustment of the cable anyway.
Why not take it to a pro? Their advice is usually free, and often more accurate than internet guessing. Even if it costs a few dollars for them to adjust it, or inspect, it should be worth it. I would hate to see you tear up a perfectly good trans, if you can avoid it.
Old Dec 14, 2010 | 02:49 PM
Freddy85's Avatar
Car: 85 Iroc
Sounds like the same issue I had with my 85, turned out the actual throttle valve was sticking. You might want to check that out.
Old Dec 14, 2010 | 06:00 PM
Engine: 5.0 TPI
okay then..... just got done with the tv adjust procedure (3 times) and it didn't change a thing. looks like I'll be ordering the shift kit.
jklein337
Sep 19, 2018 06:23 PM
camaro11j
Sep 19, 2018 08:49 AM
g.l.mos
Aug 22, 2015 12:02 AM
redmaroz
Aug 16, 2015 11:40 PM
TreDeClaw
Aug 14, 2015 06:58 PM
