700r4 to th350 swap
Old Feb 7, 2011 | 10:46 PM
jaymoung's Avatar
Car: 1984 Camaro z28
Engine: 350 small block
Transmission: 350 Turbo
700r4 to th350 swap
whats all required
i have a 86 camaro original 5.0 305 engine and 700r4 my biddy haves a 350 turbo that didn't fit on his old engine hes giving me a deal on it and im just wondering whats all required to get this tranny bolted on my engine and rolling
don'tknow if its a long or short tail nor do i know the year the tranny i can get if needed
Old Feb 7, 2011 | 10:49 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Re: 700r4 to th350 swap
No reason to do this swap so don't you are not going to get any more performance and it will hurt your gas mileage.
Old Feb 7, 2011 | 11:01 PM
jaymoung's Avatar
not looking for performance just looking to get the car driving i bought it with a bad tranny(no gears) if the swap + 350 cost as much as a 700 r4 ill just get a 700r4 but like i said im getting a good deal next to nothing just wanna know how much work is needed
Old Feb 7, 2011 | 11:03 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Should be a straight bolt in.
Old Feb 7, 2011 | 11:10 PM
jaymoung's Avatar
what about driveshaft and tv cables etc?
Old Feb 7, 2011 | 11:13 PM
jaymoung's Avatar
and crossmember?
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Same driveshaft should work no problem, the 350 is vacum regulated so just run a vacum hose to the intake.
Old Feb 7, 2011 | 11:23 PM
jaymoung's Avatar
also this might be a very stupid question but im gonna ask it anyway when buying a used transmission is there anything i can look for to tell me if the tranny is any good i know a bad tranny with burnt gears will have a odor and color change to the fluids but what if the gears are not burnt?
Old Feb 8, 2011 | 04:00 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
He will need a kickdown cable for passing gear.
OP no real way to tell, they all end up with junk in the pan and smelly fluid and can run like that on the same fluid for 50 years.
Or it can look all brand new, n be trash in 3 days.
If its a real buddy, if its crap once installed, he gives a refund or else, as you know where he lives
Its not a big deal or allot of work, well they are heavy as sin
buy some long bolts or section of all thread that will screw into the block, cut the heads off and screw into the block, the two far side bottoms, Use those as guide pin to put the trans on and slide it up to the motor to get a bolt started else where. Then remove and put in reg bolts.
Though also making sure the torque convertor is in right, is a big deal kinda.
only as it can feel like its in right, but its not. Put it in wrong and its chews up the front pump.
And what the "deal"
should be able to get a rebuilt th350 for $5-600 local easy with a good core to exchange, a Built th350 with all the goodies is only a bit over a grand.
paid $1195 for mine shipped from AZ to Ohio, no core charge, shift kit, 5 clutch mod, 3.08 1st, 2200stall TC
Old Feb 10, 2011 | 10:35 AM
jaymoung's Avatar
someone said i was gonna need a torque arm mount?
i letting me get it for 50 bucks and was wondering if its a remove and install process or how much extra will be required...its still very very cold here in michigan so i might be paying someone to do it
Old Feb 10, 2011 | 11:33 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Yes, you will need a torque arm mount, and a crossmember - most the 3rd gen F-body crossmembers incorporate the torque arm mount. Like this: http://www.umiperformance.com/catalo...bdq3liis264de1
I want to say there are 3 different tail shaft lengths, and to use your stock driveshaft you need the middle one. I think it's 6", 9", 12" tailshafts, and you need the 9". Search this - I may be remembering wrong on the lengths and which one (maybe it's 3, 6, 9 and you need the 6). There's 100's of TH350 swap threads here.
Old Feb 10, 2011 | 12:10 PM
frankinmaro's Avatar
Car: 87 Frankinmaro
Engine: ZZ4 short block 67 327 462 castings
Transmission: TH350-c out of Y body
Axle/Gears: 97 4th gen Torsen 3.23
for my th350 swap: first I bought the B&M kit for the torque arm its ok but then I went with a spohn x-member(you can use your x-member but need to make a small adapter plate because the bushing mount is different) and torque arm,you will need a driveline depending on which tail shaft the tranny has try to find one from a third gen that had a 200-r in it(same length and front yoke as a short tail th350)if its a short tail.or you can get from spohn for just under $400.I also went with a hurst shifter.check the bolt pattern on the flex plate to see if its a dual pattern plate
camaro11j
Sep 19, 2018 08:49 AM
LittleFranks
Sep 17, 2015 12:22 PM
C409
Sep 1, 2015 03:42 PM
spaigo
Aug 21, 2015 07:46 PM
TreDeClaw
Aug 14, 2015 06:58 PM
