What do you think of this ring and pinion patter?
Old Feb 19, 2011 | 02:34 PM
kerplunk318's Avatar
Check it out, let me know what you think. The one with the dial indicator is the drive side, the other is the coast.
Attached Thumbnails What do you think of this ring and pinion patter?-imag0036.jpg   What do you think of this ring and pinion patter?-imag0037.jpg
Old Feb 19, 2011 | 03:25 PM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
Re: What do you think of this ring and pinion patter?
Looks good you can try for perfection but these rears always seem to make a small amount of noise. Your pattern does look good though.
Old Feb 19, 2011 | 03:33 PM
Twin_Turbo's Avatar
Move pattern further to the root, it's on the outside too much
Old Feb 19, 2011 | 03:55 PM
big gear head's Avatar
Th e pinion is not deep enough. Add about .005 to the shim and try again. Post more pictures.
Old Feb 26, 2011 | 11:09 AM
This is .034 behind the pinion bearing with a tight (.06) BL.
Attached Thumbnails What do you think of this ring and pinion patter?-034drive1.jpg   What do you think of this ring and pinion patter?-034drive2.jpg   What do you think of this ring and pinion patter?-034coast.jpg
Old Feb 26, 2011 | 11:11 AM
This is .034 behind the pinion bearing with the backlash fixed (.011) I feel as if I could go another 5 thou in the pinion... what do you all think?
Attached Thumbnails What do you think of this ring and pinion patter?-034drivebl11.jpg
Old Feb 26, 2011 | 12:36 PM
OK I think the pinion depth is good at .037. Now the backlash is between .06 and .09 in different places around the gear. Should I open up the backlash to move the pattern more towards the heel?
Attached Thumbnails What do you think of this ring and pinion patter?-037drive.jpg   What do you think of this ring and pinion patter?-037drive1.jpg
Old Feb 26, 2011 | 02:32 PM
Ok this is .037 pinion with the backlash around .011, I'm not making any more adjustments today. I tried a .040 behind the pinion but the pattern was too far toward the root.
Attached Thumbnails What do you think of this ring and pinion patter?-imag0052.jpg   What do you think of this ring and pinion patter?-imag0053.jpg
Old Feb 26, 2011 | 04:28 PM
You need to post pictures of the coast side too. You are close, but I need to see both sides of the tooth.
Old Feb 26, 2011 | 04:38 PM
Coast .037 pinion, .011 BL
THIS WAS .040 BEHIND THE PINION
Attached Thumbnails What do you think of this ring and pinion patter?-imag0054.jpg   What do you think of this ring and pinion patter?-imag0055.jpg
Old Feb 26, 2011 | 04:50 PM
I think you've got it. What was the manufacturer's recommended backlash for the gears?
Old Feb 26, 2011 | 05:56 PM
its .010 +/- .004 but the less the lash the further the pattern is to the toe which makes me feel like its going to whine. I just want it to be as quiet as possible, I'm in no rush...
Old Mar 1, 2011 | 06:30 PM
Ok I'm gonna try to go a little deeper with the pinion, will 1 or 2 thousandths in the pinion shim make a difference in the pattern?
Old Mar 1, 2011 | 09:06 PM
Yes it will. What are you trying to improve? Post more pics.
Old Mar 3, 2011 | 05:38 PM
The last images I posted were actually with .040 behind the pinion (I amended the post.) The pictures below are with .042 behind the pinion. Why is the pattern so close to the toe? Its pretty much off the edge. The backlash ranges from .009 to .014 checking different spots around the ring gear.
The drive side seems to be more centered between the root and crown but the coast side doesn't look at good as when the pinion had .040 behind it.
What do you think I should do?
Attached Thumbnails What do you think of this ring and pinion patter?-imag0056.jpg   What do you think of this ring and pinion patter?-imag0057.jpg   What do you think of this ring and pinion patter?-imag0058.jpg
Old Mar 3, 2011 | 05:55 PM
Looks like the pinion is too deep now. Your pattern has shifted toward the root of the tooth.
Old Mar 3, 2011 | 05:58 PM
Good deal, I will go back to the .040, is there anything else I should be aware of during the final assembly?
Old Mar 3, 2011 | 06:04 PM
Be carefull when setting the bearing preload. It's real easy to go too far, and then you have to get a new crush spacer and start over again.
LT1Formula
Oct 8, 2015 08:34 PM
gord327
Oct 3, 2015 01:25 PM
FormulasOnly
Oct 2, 2015 05:52 PM
Numbah-1
Oct 2, 2015 08:27 AM
gord327
Sep 29, 2015 10:18 PM
