please help TKO swap
Old Apr 10, 2011 | 09:02 PM
grod98's Avatar
Car: 86 irocz
Engine: 383 2x4
Transmission: tko 600 rr
Axle/Gears: 10 bolt cone type posi 4.10 discs
first off this is my first post here so thanks in advance. ive been doing alot of reading trying to find out some solid info on putting a tremec tko 500 or 600 into a third gen with no luck.. i have a 383 stroker motor im pulling out of a auto monte carlo my torque arm mounts to the subframe connectors so its not a issue i have a built up stock rear a stock bellhousing that was mated to a t5 im ready to start buying i just dont know what exactly i should be getting.. id dont know much about the driveshaft length or yolks or if the bellhousing will work.. im in the market for a trans ,clutch,flywheel , bellhouse? any info on this swap would be awesome
Old Apr 11, 2011 | 07:19 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: please help TKO swap
there are a few threads on this topic on the first page of the trans forum, and if you search, you will find more. Have a look
short and dirty,
trans needs to be a specific 3rd gen f-body version, has longer input shaft
need adapter plate to use the stock bell
DS length is fine, but you need a ford C6 31 spline yoke
shifter is 2" too far forward, you need an offset shifter of somekind.
trans crossmember needs light mofidication.
some simple wiring.
Look up Fortes Parts Connection. They can set you up with almost everything you need.
Old Apr 14, 2011 | 09:15 PM
Fei's Avatar
Fei
Car: 1989 Trans Am
Engine: 94 383 LT-1
Transmission: Tremec 3550
I went through Fortes for mine many years ago. I second that.
I would recommend a Steeda Tri-ax shifter. It fits perfect in the fbody.
Old Apr 15, 2011 | 06:20 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
not quite, the tko version is a little low, but with some work its a great shifter, have on in my 86
Old Apr 16, 2011 | 02:43 AM
Fei's Avatar
Fei
Car: 1989 Trans Am
Engine: 94 383 LT-1
um I run it too and it has 2 settings. The upper one is slight bit tall and the lower one is perfect. perhaps it is a cross member difference. I run the spohn swap one.
Old Apr 16, 2011 | 09:51 AM
grod98's Avatar
Car: 86 irocz
Engine: 383 2x4
ok so i called fortes hes setting me up with a tko 600 and everything else i need hes only two hours from me so im going to pick it up next week. so thanks to you guys for the refferal. he says i might have to get the driveshaft cut? this is the only thing i dont know about. 86ta u say driveshaft lenghth is fine .. does the c6 yolk make up the difference ?
Old Apr 16, 2011 | 01:58 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
any pics? i had the trans as high as possible, touching the floor, and it was still low. maybe its the **** im using?. I have also since modified the trans tunnel and rasied the trans up and its better now, but i still had to lengthen the stock an inch.
Old Apr 16, 2011 | 01:59 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
my drivehaft was fine with the 10 bolt and with the moser 9" rear. you can use a 98-02 aluminum shaft if you want, since its about 3/4-1" shorter than a 3rd gen one.
my DS is 41.5" center to center on the joints and the ls1 shaft i have in my 92 is 40.5
Old Apr 17, 2011 | 08:04 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
can i see some pictures of this shifter? 86TA, do you have any pics, i wanted to try out the Tri-Ax is it just the handle you guys are using or the base too? my custom one feels sloppy
Old Apr 17, 2011 | 03:55 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
use the whole thing, i think the bolt pattern is different from the stock hurst shifter anyway
dont have any pics handy, i can get some tonight maybe
Old Apr 17, 2011 | 06:07 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
here we are
this is with the trans sunnel modified and the trans about 1/2" higher at the trans mount than is possible with a stock tunnel, and the stick extended 1" and moved to the driverside 3/8"
no ****
1st
5thName:  P1000031.jpg
neutral
Old Apr 17, 2011 | 06:08 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
2nd
4th
before i modified the tunnel and lengthed the stick, the **** would hit the console in 2 4 R
Old Apr 20, 2011 | 03:22 AM
Fei's Avatar
Fei
Car: 1989 Trans Am
Engine: 94 383 LT-1
Might be a TA thing. Mine was in a camaro then I put it all in a TA. Only difference is I'm running 4th gen dash and console now.
Old Sep 28, 2019 | 01:38 PM
mxcowboy's Avatar
What exactly is it you do to modify the tunnel?
deracer
Apr 11, 2016 12:04 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
