make a nwc t5 into a wc t5?
Car: 92 25th anv camaro rs
Engine: 305 tbi
Axle/Gears: 3.08s non posi
well my nwc t5 is gona need a rebuild soon, and since i cant put a t56 in my camaro i was wondering can i just rebuild my t5 into a stronger t5? by using the wc t5 rebuild kit? or some other rebuild kit to better stand up against my driven and evently power add ons?
Car: `86 SS / `87 SS
Re: make a nwc t5 into a wc t5?
Engine: 305 tbi
other then the obvious way is it possable? (smart ***, lol guess i shoulda expected it considering i said the same thing to myself haha)
thansk for the info...the answer is no
it waz hell finding a nwc t5...now to look for a wc t5.. thatll be a while.
it waz hell finding a nwc t5...now to look for a wc t5.. thatll be a while. Junior Member
Car: 1984 Z28 / 2001 Maxima SE
Engine: L69 / VQ30DE
Transmission: T5 / Auto
Is there any other modification needed to fit a WC in place of a NWC t5? I ask because my NWC in my 84 Z28 is whining and leaking from every possible source, might as well upgrade if I have to pull it out for a rebuild. I heard there was a difference with rear main seals or something?
Engine: 305 tbi
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
seeing as i rebuilt both of them, i know what the differences are. from experience, if you want performance it's not an upgrade. You need a replacement, t56, tremec, etc...
jmd and 86z are both correct.
Couldn't care less what some "link" says. The cases are DIFFERENT. Any link that says otherwise is WRONG. ANYbody can post ANYthign about ANYthing on the Internet; just being posted is no "proof" of truth.
Specifically, all the parts of the case having to do with the countergear bearings, is COMPLETELY different. The 2nd design has a bolt-in retainer for example, that the 1st design does not. The 2nd design uses tapered rollers with preload, where the 1st design uses straight rollers. (In fact the rear CG bearing in the 1st design is the same part # as a 10-bolt axle bearing.)
No way to turn the one into the other, except by the tried-and-true "2-step" method.
The difference in "torque" "ratings" is COMPLETELY TRIVIAL. They are equally weak. The main difference, to the end user, is the 2nd design will give about .01 more mpg, due to less internal friction, as its intermediate gears ride on roller bearings on the mainshaft, rather than bushings like the 1st design uses (and old 4-speeds as well).
mustangman65_79
Aug 11, 2015 03:17 PM
