How do I find out...
Old Jul 14, 2011 | 01:40 AM
350tpiirocz's Avatar
Car: 89 Camaro IrocZ
Axle/Gears: 9 Bolt
I have an 89 Iroc it's got a 350 but that's all I know about it. How do I find out what tranny and gears it's got?
Old Jul 14, 2011 | 01:42 AM
90 camaro cj's Avatar
Car: 1990 camaro RS
Engine: 305 TBI
Re: How do I find out...
there is two choices for trannys does it have 2 or 3 pedals on the floor, 2 its a 700r4. 3 its a t5. engine will be a TPI unless its been changed. gears will be able to tell unless theve been changed once you figure out your tranny
Old Jul 14, 2011 | 01:44 AM
Car: 1990 camaro RS
Engine: 305 TBI
on second thought, you could only get a 350 with an automatic, so its a 700r4 look at the RPO code to find out the rear end ratio
Old Jul 14, 2011 | 02:00 AM
Axle/Gears: 9 Bolt
Wheres the ROP code found?
Old Jul 14, 2011 | 01:38 PM
Axle/Gears: 9 Bolt
If it Helps I have 4 wheel disc brakes. I've seen many camaros with drum on the rear. dose that help?
Old Jul 14, 2011 | 03:10 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
If you have an 89 equipped with OE rear discs (11.7" rotors and single piston alum PBR calipers), you should have a 9-bolt. The following should be an interesting read:
https://www.thirdgen.org/forums/faq-...now-about.html
Though the gear ratio is a bit different, 10-bolt info should be somewhat helpful:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Jul 15, 2011 | 04:02 AM
Axle/Gears: 9 Bolt
Cool thanks! I did read the link you posted and, it got me wondering, how do I find out the gear ratio?
Old Jul 15, 2011 | 05:45 AM
JamesC's Avatar
Jerk the diff cover. The numbers are stamped on the ring and pinion. For example: 41 (ring gear) divided by 15 (pinion) = 2.73.
JamesC
Old Jul 15, 2011 | 08:24 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Two gear ratios for the 9-bolt with a 350 in 1989. 2:77 standard or 3:27 option, and in most cases it is the 2:77 ratio. So don't get your hopes up a about it being the 3:27, only 1426 Iroc 350's came with this option out of 12000 plus 350 Iroc's in 1989.
Old Jul 15, 2011 | 11:38 PM
Axle/Gears: 9 Bolt
Cool thanks guys! Huge help!!
83 Crossfire TA
Jan 3, 2016 01:26 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
NiG
Sep 7, 2015 11:25 PM
