removing TCC lock-up valve
Old Jul 27, 2011 | 03:24 PM
1killerolds's Avatar
I'm installing a 3000 stall non-lockup converter in a friends f-body. read the posts about removing the seal and check ball and installing a non-lockup valve in the pump. My question is does the pump have to come out of the trans or can it be done just by dropping the pan?
Old Jul 28, 2011 | 02:00 PM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: removing TCC lock-up valve
you can drop the pan. If I remember correctly the valve is right above (vertical standing) the tcc solenoid. Solenoid comes out with 2 bolts and the valve is in with a clip. Again that is if I remember right.
I just figured you could unhook the wiring and everything would be fine. I didnt know you had to replace the valve.
Old Jul 28, 2011 | 04:07 PM
thanks for the info. I was just going off info I found on this forum when I searched for "non-lockup converter in a lockup trans". There is a kit from Trans-Go to replace the tcc lockup valve in the pump. I bought a converter from a member on here and it came with the kit. I read about it here: https://www.thirdgen.org/forums/tran...-question.html
Old Jul 28, 2011 | 04:12 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Non lockup converter will also generate more heat. It will feel a little mushy too during normal driving.
Make sure properly seat the converter and have atf in it.
Normally for street driving lockup is perferred.
Old Jul 28, 2011 | 09:37 PM
Pro Built Automatics's Avatar
What diameter is the torque converter? What brand? What rear end gear ratio? Do you have an external cooler here?
Old Jul 29, 2011 | 09:58 AM
30 spline 9" non-lockup built by ohio converter, purchased from a member on TGO. 3.73 rear gear, external cooler being installed in-line between the trans and radiator. this converter is going in a '86 fireturd with a carbed 355, 9.6 compression, dart 180cc iron heads, comp cams xr282hr cam, roller rockers 1.5 int, 1.6 ex, edelbrock rpm air gap intake, holley 750dp,
Old Jul 30, 2011 | 06:17 PM
Without knowing the stall, you will have to try it and see how it acts.
Old Aug 1, 2011 | 06:48 AM
my bad. I left out that it is supposed to flash at 3000.
Old Sep 12, 2011 | 12:34 PM
dropped the pan, removed the filter, removed the tcc solenoid, removed the internal snap ring and the valve, washer, and springs came out. I asked this question because it has been a long time since I did any trans work. pretty straight forward. got the non-lockup valve and spacer in. removed the check ball capsule if the end of the input shaft and the o-ring. slid the converter in. had to use 1/2" spacers between the flywheel and torque converter bolt pads. filled up with atf and pulled a few hole shots. seems to work good.
Cameeeero
Sep 18, 2015 04:00 PM
backtothe80s
Sep 5, 2015 12:39 AM
NBrehm
Aug 25, 2015 11:49 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
3rdgenparts
Aug 8, 2015 07:09 PM
