89 formula tranny mount (how hard to fix?)
Old Aug 24, 2011 | 12:54 PM
ChaseHammer's Avatar
Car: 1997 Pontiac Formula
Engine: 350 LT1
Transmission: Manual
Hey im in contact with a guy that i might buy his 89 Formula however the transmission mount is busted. I was wondering how hard it is to change out.
I read the instructions on the site just curious how much work it would be. Also if i were to leave it alone for now, how much trouble does it cause to the car.
This would be my first 3rd gen car. Thanks.
Old Aug 24, 2011 | 01:00 PM
torque_is_good's Avatar
Re: 89 formula tranny mount (how hard to fix?)
Drive front onto ramps or place front onto jack stands
get a 1 foot section of 2x4 wood and also a floor jack
go underneath car
remove the one nut holding the tranny mount. It's on the cross member
place wood onto jack and jack up tranny by aligning the wood with the tranny pan. Lift it about 1 inch. To make it easier, remove the 4 bolts holding the crossmember
remove nuts holding tranny mount
reverse process
oh, tighten the tranny pan bolts or better yet, once you get the mount and crossmember back on, drain the tranny and change the filter/fluid
Old Aug 24, 2011 | 01:28 PM
Engine: 350 LT1
ok so we are talking about what a hours worth of time? Not bad.
any downside of not doing it right away?
Old Aug 24, 2011 | 01:31 PM
Seven_MPG's Avatar
Car: 1985 Z28
Engine: '69 350 4 Bolt Main .30 Over
Transmission: 700r4/B&M Shift Kit and Flywheel
Axle/Gears: GM 10 Bolt 3.23 Gears
Any hard launching could cause pretty substantial wheel hop,also cause the tailshaft of the trans to slam the floor pan.
Old Aug 24, 2011 | 02:43 PM
Engine: 350 LT1
cool thanks guys.
ill think ill have myself an addition to my bird family in the next couple days.
Old Aug 24, 2011 | 03:11 PM
Seven_MPG's Avatar
Car: 1985 Z28
cool thanks guys.
Make sure to post some pics when you get it.Welcome to the forum.
Old Aug 24, 2011 | 03:52 PM
it's not an option; replace it.
Old Aug 24, 2011 | 03:57 PM
Engine: 350 LT1
well i joined back in 2004 because my girlfriend at the time had a 89 Rally Sport. i posted once awhile ago. I mostly read things not posting but now with this new purchase ill probably be around more.
And i was going to replace it just wasnt sure if this caused some horrible trouble down the road if it wasnt done right away, i have to drive it back home and whatknot.
mustangman65_79
Apr 14, 2017 05:37 PM
Bert87
Aug 23, 2015 03:50 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
