Is there a way to add a drain bolt to the transmission?
Old Sep 10, 2011 | 10:21 AM
SXN's Avatar
SXN
I was browsing some threads and noticed some of the guys saying that you can add a drain valve/bolt to the transmission casing?
I would like to do a drain and fill often to keep my tranny going.
Was wondering if there's a way to do this without taking the pan off.
Old Sep 10, 2011 | 10:25 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Is there a way to add a drain bolt to the transmission?
A drain has to go in the pan.
Old Sep 10, 2011 | 10:44 AM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
you have to take it off to drill and tap the pan... thats what i did.... i dont see how you can do it with the pan on because all the little shaving will be inside the tranny if you dont get it out...
Old Sep 10, 2011 | 10:49 AM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
If you add a drain plug, put it on the SIDE (or back...a vertical part) of the pan, like how the engine oil drain plug is, not on the bottom. I put mine on the bottom & promptly drug it over on incline & got a slow leak. I was lucky it was just a slow leak & not completely ripped out & drained all the fluid out.
Old Sep 10, 2011 | 11:12 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Don't bother. Clean tranny fluid is awesome, but it doesn't need to be done that often.
And when you change your fluid the pan has to come of anyway in order to change the filter.
Old Sep 10, 2011 | 11:13 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Still nice to be able to drain the pan before you take it off to change the filter.
Old Sep 10, 2011 | 11:37 AM
Car: GTA
A tranny drain plug sure makes dropping the pan to reach the filter a lot cleaner. No more tranny fluid bath & fluid all over the garage/driveway or fluid mud pile in the dirt driveway or grass (if that is all you have).
Old Sep 10, 2011 | 01:32 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Oh yes, give thanks to those OEs who have gotten the idea and have put drains in their trans pans from the factory. Even after decades and hundreds of pan drops, I still fight doing the job without spraying fluid over the bay floor.
A few quality aftermarket pans come with drain plugs installed. The quick fix DIY plug kits aren't as neat as they sometimes leak.
Old Sep 10, 2011 | 02:14 PM
SXN's Avatar
SXN
Thanks for the tip.. I just have to find a shop that will put a drain in for me now
Old Sep 10, 2011 | 03:19 PM
jakemussman's Avatar
Car: 1990 Camaro RS
Axle/Gears: 10 bolt, 3.73 Ratio, Torsen LSD
I wouldn't pay a shop to do it! Its pretty straight forward. You should be able to do it yourself and save a lot of money.
Old Sep 10, 2011 | 03:29 PM
Car: GTA
if you have the space & tools.
Old Sep 10, 2011 | 03:53 PM
0pyders's Avatar
Car: 86 Firebird LG4
Axle/Gears: 3.23 limited slip
http://www.summitracing.com/parts/SUM-G3886/?rtype=10
Old Sep 10, 2011 | 03:59 PM
Car: GTA
Drain plug on bottom =Bad choice, especially for a lowered car. I drug mine at stock height & it caused the leak.
Old Sep 11, 2011 | 09:16 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
And be careful of where the drain is placed. Some areas under the pan are tight and the plug will hit the trans.
IIRC, I placed it in the right rear side of the pan.
RBob.
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Reddeath210
Oct 6, 2015 08:20 AM
