What is the thread pitch of a T5 drain plug
Old Nov 2, 2011 | 02:40 PM
LostX's Avatar
Car: 88 Trans Am
Axle/Gears: Posi
i am going to install a temperature sender for a trans temp gauge in my car so i dont blow the tranmission up again.
i would like to know what the thread pitch is for the drain plug in a t5 transmission.
Old Nov 3, 2011 | 03:06 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: What is the thread pitch of a T5 drain plug
Pull yours out and put a thread pitch gauge on it. I wanna know too.
Old Nov 3, 2011 | 04:33 AM
85Z28NOS's Avatar
Car: 85 Camaro
Engine: 454 RamJet
Transmission: LT1/T56
Axle/Gears: 8.8w/4.10
If memory serves me its 1/2"npt pipe threads. I will double check tomarow while im working on my body brace
Old Apr 16, 2012 | 04:57 PM
jmd's Avatar
jmd
1/2-14 NPT
Old Apr 16, 2012 | 05:03 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
yup, 1/2 npt
Old Apr 16, 2012 | 05:29 PM
jmd's Avatar
jmd
anyone know where to get one that's magnetic? The dorman one (090-100 IIRC) is NOT coming in as the right thread from multiple distributors.
Old Apr 16, 2012 | 05:32 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
dont know if magnetic plug will prove anything in this application. the drain plug is on the "top" passenger side, of the trans since it sits on an angle. any sediment will settle to the "bottom", driverside of the case, and away from the drain plugs. there is a magnet in the case for this purpose. grab a little bolt and move it around on the bottom of the trans, you will find a spot where it "sticks"
Old Apr 16, 2012 | 05:36 PM
jmd's Avatar
jmd
Yup, yup.
It's not for a T5.
I don't need one for me.
It's a customer. I reassured him the internal magnets would do fine for the service life of the trans.
Old Apr 16, 2012 | 05:41 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
what size do you need? summit has just about everything.
http://www.summitracing.com/parts/TRD-9064/
thats a 1/2 npt one. Not going to help if you need one locally though
Old Apr 16, 2012 | 05:50 PM
jmd's Avatar
jmd
thanks!
db057
Jan 10, 2020 08:55 PM
Elephantismo
Feb 13, 2019 12:51 AM
tyeo098
Nov 30, 2015 06:27 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Night rider327
Sep 16, 2015 02:20 AM
