new guy with trans. issue
Old Dec 6, 2011 | 10:13 PM
cooper3's Avatar
Axle/Gears: 3:73
Well hello im new to the website and have a few questions. I just bought a 1984 z28. its got a 350 with 700r4 tranny. The tranny blew up the next day i took it out and decided i would have it rebuilt. But when he took out the part the holds all the clutches all teeth where broken. so i decided to buy a used tranny i found a good one from a faimly freinds freind. its a 700r4 out of a mini van of some type. i havent got all the details yet but what are some problem i might run into buying this?? will my cross member work? is it in the same place on all the 700r4s? i already have a new torque converter hopfully its the same amount of spline numbers as my other one. Im not racing the car just my everyday driver. nothin real fancy bout it. i just really need a car like now!! also another question there is a 4 prong conector on the driver side of the car its like a squar what is that for?
Old Dec 6, 2011 | 10:20 PM
LsxMatt's Avatar
Car: 86 Sport Coupe
Engine: 5.3 LM7
Axle/Gears: 4th gen 3.42 posi
Re: new guy with trans. issue
It sounds like your talking about the teeth on the input drum for the 3-4 pack. Why not just replace the drum and use the same tranny? They go used for about 50 bucks. Who is building it? Also the connector is for the lockup for the converter. As long as the van tranny is a 700-r4 it will work. Just make sure its a 700 and not a 4l60-e.
Old Dec 6, 2011 | 10:25 PM
cooper3's Avatar
Axle/Gears: 3:73
Just a guy who rebuilt y dads tranny already. I was going to go that route but... im short on money. Im trading some stuff for this. I did find the part local for 35. But i need the car asap is another problem its going to take at least untill this weekend to get it finished.
Old Dec 6, 2011 | 10:39 PM
cooper3's Avatar
Axle/Gears: 3:73
also i was wondering if the shifting cable will be diferent from the steering colume to the center colume? sorry im not exaculy sure how to word it.
Old Dec 6, 2011 | 10:41 PM
LsxMatt's Avatar
Car: 86 Sport Coupe
Engine: 5.3 LM7
Reuse the shift cable on the camaro and you may have to reuse the dip stick tube off of the camaro 700
Old Dec 6, 2011 | 10:45 PM
cooper3's Avatar
Axle/Gears: 3:73
ok what about the cross member? any idea if it is in the same place?
Old Dec 6, 2011 | 10:47 PM
LsxMatt's Avatar
Car: 86 Sport Coupe
Engine: 5.3 LM7
The transmissions are identical. Reuse your camaro parts.
Old Dec 6, 2011 | 10:49 PM
cooper3's Avatar
Axle/Gears: 3:73
ok thanks for the help do you know what the 4 prong conector is? my camaro doesnt have the plug?
Old Dec 6, 2011 | 10:55 PM
LsxMatt's Avatar
Car: 86 Sport Coupe
Engine: 5.3 LM7
That's for the converter lockup. That locks the converter in 4th to drop the rpm on the highway to save fuel. You can do without it, just will burn more gas. If you want to use it you will need a lockup converter, a harness and a computer from a car with lockup. You can probably wire it up somehow without the harness, and use a manual toggle switch but I'm not 100% on that. I just know how to do it through the dl connector on an already equipped car.
Anyway, you Can do without it as not all of the cars were equipped with it anyway.
Old Dec 6, 2011 | 11:01 PM
cooper3's Avatar
Axle/Gears: 3:73
ok cool that takes my stress level way down. thanks for all the help buddy!
84z96L31vortec
Aug 20, 2017 12:16 AM
87 camaro iroc
Aug 20, 2015 07:47 AM
Street Lethal
Aug 14, 2015 08:25 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
Leggman1
Aug 6, 2015 04:15 AM
