t5 short throw
Old Jan 5, 2012 | 09:41 PM
grayghostv6's Avatar
Car: 1988 camaro rs/ 1991 camaro rs
Engine: 2.8 v6/ 5.0 TBI (soon to be TPI)
t5 short throw
I'm getting ready to swap in a t5 to my '91 but I'm having trouble tracking down a short throw shifter for it. Can anyone hit me up with some links to check out?
Old Jan 5, 2012 | 10:06 PM
LostX's Avatar
Car: 88 Trans Am
Axle/Gears: Posi
Re: t5 short throw
http://www.ebay.com/itm/Hurst-CHROME...6#ht_782wt_762
i bought this
Old Jan 5, 2012 | 10:31 PM
irocarter's Avatar
Car: 89 iroc
Engine: 5.7 trick flow heads t-ram
Transmission: wct5
Re: t5 short throw
Definately spend the extra 20 bucks for the shifter stops
Old Jan 6, 2012 | 10:53 AM
LostX's Avatar
Car: 88 Trans Am
Axle/Gears: Posi
Re: t5 short throw
yea i bought the stops from that guy as well. and the price is fair
Old Jan 7, 2012 | 03:56 AM
Pat Hall's Avatar
Re: t5 short throw
I agree, the Hurst is a good unit. The other good one to look at is the Pro 5.0 shifter. B&M's Ripper is the cheapest, but most guys say the Hurst and the Pro 5.0 are better units. Btw, one advantage the 5.0 has over the Hurst is it has the same **** thread size as the factory shifters. That's the only downside to the Hurst is your choice of shift ***** is pretty limited.
Old Jan 7, 2012 | 05:54 AM
robvano's Avatar
Car: 72 Chevelle
Engine: 468
Transmission: Muncie
Axle/Gears: 355
Re: t5 short throw
I like using the Hurst shifter on a T5 with an additional inch removed from the shaft. It’s much easier and comfortable shifting than the stock unit. I refinished the shaft in satin black, but it was not necessary because the stock boot covers the shaft completely.
Last edited by robvano; Jan 7, 2012 at 06:09 AM. Reason: added pict of hurst shifter w shortened shaft
Old Jan 7, 2012 | 07:28 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: t5 short throw
For the sake of information, the B&M Ripper also accepts the OE **** (though I'm using the Hammer T shifter).
JamesC
Old Jan 7, 2012 | 05:58 PM
85FBTranam's Avatar
Car: 1985 Pontiac Trans Am
Transmission: BW T5, Hurst Short Throw Shifter
Axle/Gears: 3.70 Posi
Re: t5 short throw
Ordered the part from the same eBay vendor. Was one of the most rewarding bolt in installs i've done. Shifter travel is significantly reduced and spring tensions on the shifter rod feels great. If you have the shifter out, check the condition of the vibration damper cup. They are still available from GM, are relative cheap and good insurance.
Old Jan 7, 2012 | 09:42 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: t5 short throw
I'm a big fan of the Pro 5.0 shifter on the T-5 trans.
Old Jan 10, 2012 | 12:12 AM
Pat Hall's Avatar
Re: t5 short throw
JamesC
Thanks James, I totally forgot to mention the Ripper has the right threads too! I had a Hurst Billet Plus for a while, and I gotta admit the tension and feel of it was awesome. I just hated the fact that my choice of nice shift ***** was so limited. Even Hurst's own line of *****, most of them are 3/8x16 thread, and the T5 Billet Plus is 7/16x24.
Old Jan 10, 2012 | 07:29 PM
irocarter's Avatar
Car: 89 iroc
Transmission: wct5
Re: t5 short throw
Just retap the stick to whatever thread you want.
Old Jan 10, 2012 | 07:44 PM
Re: t5 short throw
The Hurst is easy to fix that though; back before I realized how stooooooopid it was to keep trying to keep T-5s working, I had made a bushing with the inner threads for teh Hurst and the outer threads for the stock ****, so I could pair them up. Looking into the car you couldn't tell it wasn't stock except that if it was in 1st 3rd or R the shifter **** wasn't up against the radio ***** any more.
Can't just "re-tap" it. The shifter is like 3/8"-24, and the stock **** is about 14mm. About like trying to "re-tap" a TPS screw into a main bolt hole.
Old Jan 11, 2012 | 08:33 AM
Pat Hall's Avatar
Re: t5 short throw
Yeah like Sofa said, you really can't just "retap" it since the factory thread size is HUGE compared to Hurst's 7/16 x 24. Also like Sofa said, I too actually gave up on using a T5 before ever using one. After going through all the trouble to get a nice shifter for one, I just ended up putting in a Tremec TKO instead!
Old Jan 11, 2012 | 10:57 AM
irocarter's Avatar
Car: 89 iroc
Transmission: wct5
Re: t5 short throw
yes---you can "retap" a 7/16x24 stick to a3/8x16 thread. This way you have more options for shift *****. Not everybody wants that big ugly plastic POS **** that GM used anyway.
Old Jan 11, 2012 | 05:31 PM
Re: t5 short throw
Don't know about that kind... mine is the leather-wrapped one that looks about like a small black baseball
Old Jan 12, 2012 | 02:45 AM
Pat Hall's Avatar
Re: t5 short throw
I never cared for the cheap plastic **** either, and quite frankly, the stock leather, baseball type **** is too big for my taste. I ended up using the Pontiac leather **** that's sorta triangular shaped with 3 stitched seams. Smaller than the round Chevy leather ****. It's the most comfortable one I've found so far. I also considered the "SLP" leather ****, but it's like 75 bucks, and I grabbed the Pontiac one from a junkyard and just put it in my pocket, so it was free. Hell, if anyone's pathetic enough to leave the cheap plastic factory **** on there, you might as well just keep the stock, sloppy shifter too! I've got the really sharp looking solid chrome **** on my 69 Camaro's shifter, but damn that thing is cold in the wintertime! Leather **** is great in the winter.
Old Jan 12, 2012 | 09:04 AM
irocarter's Avatar
Car: 89 iroc
Transmission: wct5
Re: t5 short throw
This is the ball I'm using on my iroc. It was a bit pricey (50 or 60bucks) I saw one of these on Shane Hmeil's Craftsmen Truck at Martinsville a few years ago and had to have one. It's a cold ball to hold onto in the winter.
Fanatic1074
Oct 3, 2022 05:57 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
skinny z
Oct 5, 2015 06:23 PM
Bigold4x4
Sep 28, 2015 05:21 PM
ndndndnd
Sep 28, 2015 08:00 AM
