why does it grind when i put it in reverse?
Car: 1988 firebird formula
Engine: 5.0 tbi
Transmission: 5spd std
Axle/Gears: stock
its a 1988 305 tbi, 5 speed, firebird formula, it grinds when i shift it into reverse, why does it do that??
also do anyone know what kind of 5 speed and rear rend came with that??
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
Axle/Gears: 5 Speed Manual
Re: why does it grind when i put it in reverse?
Mine does the same thing. problem is that the flywheel isnt stopping like its supposed too. but i found this to be a very good thing to do:
before you put it in reverese put it into 5th gear but dont let go clutch and then to reverse, it wont grind anymore. because it stops the wheel. glad i can relate to someone else.
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
yup and since its going into reverse, 5th is the fastest lol imo, mine does that too, waiting to drop tranny to change clutch. GL bro
Engine: 5.0 tbi
Axle/Gears: stock
thanks, so is there a way to fix it so u dont have to put it into a forward gear first?
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
drop the tranny, and get to the flywheel and replace. just replace the whole clutch, and whilke getting a new clutch might as well save the extra 100+ to get a very good clutch.
Mostly because, it's not "broken". (yet...) That's just THE WAY IT IS. This model of trans doesn't have a synchronizer on reverse, so you just gotta learn how to drive it.
The grinding noise is the teeth of the reverse gear chewing metal off of themselves. Just jamming it into reverse while it grinds like that, fille the fluid up with metal chips, and ruins EVERYTHING ELSE in the transmission. Even though it's not tremendously harmful to reverse itself, as there's PLENTY of metal there, it DESTROYS the whole gearbox; the bearings, shafts, other gears, etc.
Whenever I'm buying a used transmission, that's one of the first things I look for, is that damage; and I won't even buy one that has it, because all the parts will have damage and wear from the metal chips.
Replacing the clutch won't change that in the slightest.
Learn to drive the car right.
Car: 1988 Iroc-Z
Engine: 350 TPI; Stock internals
Transmission: 700r4; TCI-CPVB; BW Hi-Frition
Axle/Gears: 4th gen 7.5 w/ 3:42 gear
Gotta learn to "feel" you are... Kinda like feelin a girl up for 1st time... Just gotta find her curves and DISLIKES... Yes, the dislikes are you you really need to be concerned with b/c you can get a nice slap to the face... See, your car is no different! lol
Your welcome
Car: 1992 Chevrolet Camaro RS
Transmission: Manual
I'm new in thirdgen.org and not sure if people will reply to old threads. Anyways, I just got a 1992 RS a few months ago. It's my 2nd third gen. My car does the same thing. Before going into reverse I have to quickly pop it into fifth and them back into reverse. I also have to do the same thing going into first. Except, I go into second and then back into first. What's the most cost-effective way to get this fixed?
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
You 1st gear synchro is worn out. What you are doing now is the free solution. The only way to fix this one is to remove and rebuild the transmission.
Damnit. Alright, I guess I'll just use it like this for now. Rebuilding the transmission sounds expensive.
Thanks for the help!
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
accurate clutch adjustment is a must. you should be able to go from 1st to reverse,with no grinding. its a good test of the clutch adjustment. also change the gear oil in the trans ,it will help
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Only way to know exactly what it will need is to have it cracked open
Doesnt necessarily mean youll need all new stuff.
Car: 86 iroc, 02 v6 camaro
Engine: 350 HSR, 3800 V6
Transmission: T56, WCT5
Axle/Gears: 9in 4.11 posi, 3.23 LSD
both my t5s do. one in my dd v6 4th gen and the other in my weekender 350 third gen. just the way of the game with these clunky transmissions.
Engine: 3.1 V6
Axle/Gears: No idea
Chuck84TA
Nov 28, 2012 03:41 PM
AstroturfHead
Mar 10, 2003 09:31 PM
