governor or not
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
governor or not
i have a 355 sbc with 700r4 transgo shift kit corvette servo, upgraded vanes, input shaft, and 3000 stall convertor. im having an issue at about 4500 rpm going from 1-2 it "flares" out and wont shift till i let off or keep revving it. my cams good up till 6500rpm. is the governor causing this issue by not letting it shift past 4500rpm? i have the bto tv cable setup and its setup properly. and fluids new with filter. any ideas guys?
Engine: 355
Re: governor or not
i hookd a psi gauge up and its at 200psi in idle, and i cannot get the pressure to drop no matter where i put the tv cable, what should i do
92Z
Feb 16, 2001 11:03 PM
