cup plugs
Old May 28, 2012 | 02:49 PM
brian63's Avatar
cup plugs
does anybody know where i can buy cup plugs online.
Old May 28, 2012 | 02:58 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: cup plugs
Need a little more information please.
Old May 28, 2012 | 03:13 PM
brian63's Avatar
Re: cup plugs
5/16 and 3/8 tapered
thank you
Old May 28, 2012 | 03:47 PM
brian63's Avatar
Re: cup plugs
anybody please
Old May 28, 2012 | 07:00 PM
Re: cup plugs
Alot easier to get em at a REAL parts store...
Not sure I know anything about this "tapered" though; only been doing this about 40 years or so though, I'm kinda inexperienced, maybe that's something new?
Old May 28, 2012 | 07:12 PM
brian63's Avatar
Re: cup plugs
i have tried all parts stores within 75 miles of here cant get nothing online unless i buy bulk 100,000
Old May 28, 2012 | 09:02 PM
Re: cup plugs
Where's "here"?
Tried NAPA?
What are you REALLY trying to do?
Old May 29, 2012 | 12:28 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: cup plugs
You're going to keep having that experience until you learn how to back your questions up with detail.
Old May 29, 2012 | 12:33 AM
brian63's Avatar
Re: cup plugs
i want 3/8 for plugging 2-3 accumalator
5/16 to plug reverse feed behind pump so i dont have to tap it
brian63's Avatar
Re: cup plugs
lorimor iowa
Old May 29, 2012 | 07:05 AM
Edwardgp's Avatar
Engine: 454-350
Re: cup plugs
There was one of the cups on e-bay under chevy parts.
Old May 29, 2012 | 12:29 PM
jmd's Avatar
jmd
Re: cup plugs
5/16 as 8mm here www.ebay.com/itm/150610245935
3/8 as Dorman 555-115
Not under a buck a piece at your local store like "they should be" but there you go.
Obviously, you'll save time by just tapping for a thread-in plug.
Old May 29, 2012 | 01:05 PM
brian63's Avatar
Re: cup plugs
thank you for the help
Old May 29, 2012 | 06:33 PM
Edwardgp's Avatar
Engine: 454-350
Re: cup plugs
Yes sir jmd can post the link I don't know how, anyway let us know how you did there brian63.
Old May 30, 2012 | 02:21 AM
jmd's Avatar
jmd
Re: cup plugs
eBay has irregularly changed programming of the URL over the years. Currently, deleting everything after /itm/ except for the 12 digit item number gets you a shorter link.
Old May 30, 2012 | 03:07 AM
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
Re: cup plugs
I've found that if hitting it with a hammer doesn't work, weld it.
Old May 30, 2012 | 11:10 AM
brian63's Avatar
Re: cup plugs
the one on ebay is like 10.00 dollars with s/h for one 5/16 i think ill get a 3/8 tap and set screw for reverse feed behind pump and probably block 2-3 accumalator on plate anybody know how to change th350 pump bushing backwoods style
Old May 30, 2012 | 11:11 AM
brian63's Avatar
Re: cup plugs
10-4 on bfh
Old May 30, 2012 | 06:21 PM
Edwardgp's Avatar
Engine: 454-350
Re: cup plugs
Double 10/4 on 3/8" tap.
Old May 30, 2012 | 07:43 PM
brian63's Avatar
Re: cup plugs
i dont know if i should start another topic or not but i am need of a th350 front pump bushing driver anybody know where i can get one of these
Old May 30, 2012 | 07:55 PM
jmd's Avatar
jmd
Re: cup plugs
https://www.thirdgen.org/forums/tran...g-install.html
Alternately, a piece of iron pipe machined down makes a nice cheap bushings driver.
It's guaranteed to go in easier than any F-body T56 tailhousing bushing.
Old May 30, 2012 | 08:35 PM
brian63's Avatar
Re: cup plugs
thank you
wigmobile
Feb 26, 2025 02:56 PM
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
gta892000
Aug 11, 2019 11:16 AM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
